cruise control problem
My cruise started to work less and less frequently. It is now not working at all. Fuse is ok. What fails on these systems? Is there an achiles heal on the cruise? Kevin
Kevin Gildea 71 Alfa 02 R1100s Boxer prep 86 Suzuki RG500 97 993 Cabriolet 06 KTM 625SMC 01 Yamaha WR426 92 KDX 200 85 Yamaha IT 200 |
brake light switch sticking/failing??
edit: just to be clear; the brake light switch activated by the brake pedal.
max Last edited by maxnine11; 09-06-2006 at 09:41 PM.. |
Banned
cruise control servo
the cruise control servo that goes in the engine is what most of the time goes. i have a new on or good used one, let me know..
On 993's, there is a tendency for the clutch pedal to not come up all the way. There is a switch that gets activated when you press the clutch, which tells the cruise to cut fuel. This switch gets stuck "on" when the clutch pedal doesn't come up all the way.
See this: http://p-car.com/diy/pedal/clutchlever.html And this: http://p-car.com/diy/pedal/
Downshift |
kang, many thanks for your info concerning the diy sites!!! i've been looking for such info forever! thanks again! tjn/vk
tjn/vettekiller |
Thanks all for the replies, I will dig in and see what I have. Kevin
Finally got a chance to look at the car today. Kang got this one, clutch pedal a little sticky I guess. Pull the pedal up, and cruise works. Thanks all, Kevin
