Mammalian
96740's Avatar
Exhaust system recomendations.
I need some advice on a replacement for my current B&B exhaust system. ( 1996 C2 3.6 )
I love the sound of the B&B, but the system is not fitting the way it should ( probably because it was put on several years ago and the system was quite new then) but, I would like a much cleaner, neat fitting system.
I guess my order of preferences would be ... HP, fit and finish, and than sound, but like I said the B&B is very taste-T.
2007 Cayman
Old 01-05-2008, 06:25 PM
North Coast Cab's Avatar
Basic Options that seem popular
1) Stock Mufflers - Cat Bypass
2) Fabspeed Supercup Mufflers (pipes) - OEM Cats
You can find both options often in the Pelican or Rennlist classifieds.
1985.5 944 GTS
Old 01-05-2008, 06:55 PM
I hear GHL makes a very nice system, $$$. You could also go with 993 heat exchangers with the flanges flipped around and either a M&K muffler (no cat), or use a flowmaster/dynomax/magnaflow 2 in 2 out muffler with some custom tubing (again no cat). If you decide to go with stock 964 exhaust parts with bypass. I have them for sale!
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 01-05-2008, 07:19 PM
Sorry, just noticed you have a 993 and not a 964. Either GHL, or use the stock HE's with a nice custom muffler setup or M&K makes one that will bolt right up (no cat).
Could you maybe explain how the B&B is fitting incorrectly. I am looking @ possibly going this way, but would love to avoid any problems.
Old 01-05-2008, 07:21 PM
Now in 993 land ...
aigel's Avatar
I researched exhaust and found that it wasn't worth the hassle in terms of hp. Cat bypasses are out of the question for me, as I want to keep it legal. My mufflers have had some baffle surgery by SCARGO when the car was fairly new. It helps on the exhaust note - its perfect. So, why not go back to stock with a bit of baffle mod? It sure would pay for itself if you sell the B&B.
George
81 SC (sold)
Old 01-05-2008, 10:32 PM
Bill Verburg's Avatar
It's not 100% clear what you have now.
there are 3 main sections of the exhaust which can be modified independatly of each other.
heat exchnger or header
cat or cat bypass
Her's a 100% stock 993 exhaust
mufflers
What parts are B&B?
Bill Verburg
Old 01-06-2008, 09:23 AM
Mammalian
96740's Avatar
The left side tail pipe welds are off. So to get the tip to not touch the body work, I have to tweak it and you can tell that there is something wrong with it when looking from the rear. The right side fits perfect. (see pic.) The picture of the left is what it looks like if I don't re-position it. It looks off even after I loosen the bolts and move it to the right.
I'm sure that the new systems from B&B are much better now. This was one of the first ones they did.
I may just take the muffler off and re-fab it, so the tailpipe exits the rear like the right side.
2007 Cayman
Old 01-06-2008, 09:30 AM
Does the muffler exit have the correct biscuit joints? There were 2 manufacturers of oem mufflers Gillette and Bischof
the left 2 mufflers are Gillett, they have the biscuit integral w/ the pipe exit. The right 2 are Bischof. , they have an expanded section which a separate biscuit fits into
Bischof biscuit and clamp
The clamps are the same for both different set ups. The tips are adjusted by losening the clamp and rotating the tip to suit.
Bill Verburg
Old 01-06-2008, 09:50 AM
Mammalian
96740's Avatar
The system is like the ones on the right. My mechanic and I went over it for a while and came to the conclusion that the left muffler was just welded poorly. We compared it to the right side and the measurements were way off. I'm now actually wondering if I could just buy a new left muffler from B&B, although I'm pretty sure the tips are fabricated to match each set. In which case it would look lame to have a brand new tip on the left, and the old on the right.
2007 Cayman
Old 01-06-2008, 10:37 AM
From the pics it appears that the mufflers do not hav ethe adjustable biscuit joint. So you would either need a new muffler or reweld the existing one.
Bill Verburg
Old 01-06-2008, 10:55 AM
Mammalian
96740's Avatar
I think you are right.
Thanks.
2007 Cayman
Old 01-06-2008, 11:00 AM
AM993's Avatar
I used to have the B&B on my 993 (installed by the previous owner) and switched back to stock (Motorsound) mufflers / big ovals. The fit is perfect, the sound is what Porsche intended and in terms of HP, I have not noticed a decrease from the B&B. Bottom line, I could not be happier.
'10 997.2 C2 Meteor Gray
'00 Boxster Arctic Silver - sold
95 C2 Polar Silver - Sold
Old 01-06-2008, 05:41 PM
jtkkz's Avatar
RSR Mufflers by Robin at www.p-car.com
I have a friend who has this muffler on his 993 and it sounded great...
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 01-09-2008, 12:29 PM
Mammalian
96740's Avatar
Thanks for the info/link.
2007 Cayman
Old 01-10-2008, 04:45 PM
Mammalian
96740's Avatar
Why not just nix the B&B's and put on the Fabspeed Supercup's, nice and clean and they look like they fit much better. Anyone have these? Comments.
2007 Cayman
Old 01-22-2008, 09:16 PM
It'll be pretty loud
Bill Verburg
Old 01-23-2008, 04:50 AM
I had the Fabspeed Supercups with OEM cat. They sounded awesome, but just a little too loud for my neighborhood.
1985.5 944 GTS
Old 01-23-2008, 05:24 AM
Mammalian
96740's Avatar
Loud is fine. They look like it should be easy to install. I don't have a rack, but loads of jack stands and floor jacks. Anyone done it while on their back?
2007 Cayman
Old 01-23-2008, 05:59 AM
Mammalian
96740's Avatar
Has anyone fitted the aluminum bumper heat shield exhaust thing from a WB to NB C2? Some guy on Rennlist has made it work, but...
Where does one order this part? I'm going to have to fab it. Anyone interested in this for there NB 993?
2007 Cayman
Old 01-28-2008, 08:56 PM
Mammalian
96740's Avatar
Installed the Fabspeed Supercups this morning. Wow, they are loud. The fit and finish is great. Much better then the old B&B's. Looks much better also. My neighbors are going to loooovvve me.
Thanks everyone for your input/advice.
2007 Cayman
Old 02-04-2008, 02:11 PM
