JoeMag's Avatar
993 varioram intake, what controls are needed?
On the varioram intake, what are the moving parts and what controls are needed to make it work?
Old 03-15-2008, 03:52 AM
Bill Verburg's Avatar
one throttle flap at the intake in back, mechanically controlled
there is one vacuum controlled slide per bank actuated by solenoids controlled by the DME, the slides are in long config(475mm intake length) from 0 - 4840 and move to short config(240mm long intake) @4840 & >50* throttle angle
one tuning(aka resonance) flap near the front, vacuum operated via solenoid actuated by DME signal @5840 & >50* throttle angle this is opened then closed @ 6640
Bill Verburg
Old 03-15-2008, 06:07 AM
JoeMag's Avatar
Ok, so if I have an intake that is complete, I need two control outputs from motor controller;
1 to control two solenoids for the intake runner length, and
1 to control the resonance flap
What are the thoughts on use of these in a race motor that will very seldom be below 5k rpm and 50% throttle angle? ...3.8L
Old 03-15-2008, 03:12 PM
JoeMag's Avatar
...found the answer to my questions in a search on varioram. No real bene in race motor.
Old 03-15-2008, 03:22 PM
For just 5-7k use, the old plastic manifold from a '94 or 95 is probably better
the older non vam intake also has a resonance flap
open from 0-3500 and from 5520-6640
closed from 3500-5520 & throtle >60*
ther resonance flap is actuated through pin1
but for your purpose just leave it open
Bill Verburg
Old 03-15-2008, 06:39 PM
