Emergency release cable broke off as well and came out in my hand! Now What?
IF it is installed, it's behind the left front wheel fender liner, at least that's where mine is.
Have someone press down on your hood as you pull the release cable.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Hood Latch issues
Thanks, I'll tear the thing apart and have a look!
I tried the hold the hood down trick, the release lever is loose as there is no tension on the cable. Something seems to have come loose at the latch end. |
Wine Country California!
I see you live in wine country California! Cool, I live in wine country British Columbia!
Should be the same as here:
http://www.rsamerica.net/articles/tech/keithv_front_hood_release_article.htm
-Stan 1993 RSA #164 |
Big Trouble, The emergency release cable has broke off as well ns pulled out in my hand!
Now What? Any Ideas? "HELP" |
FRENCHMAN
If you Know where to borrow one boroscope,you can try with a hook.it's tricky but it's work.Goo luck.
Pascal
964 TURBO 91 RED ARENA WITH SOME LITTLE MODS 911 3.2 CARRERA 86 SOLD BUT NOT FORGET |
