RetiredRider
RetiredRider's Avatar
Volt meter reading
With a fresh battery and the engine running, what reading at the battery should I see when testing with a volt meter? Assume the charging system is up to spec. This is a 1990 C2.
Also, has anyone installed a battery cutoff switch? What will be the effect of turning off power to the DME, then back on again at a future date?
1990 Carrera C2
2005 Honda ST1300
1978 Kawasaki KZ1000
1954 Chevy 3100 - project
Old 10-15-2011, 06:53 PM
83 911 Production Cab #10
JJ 911SC's Avatar
~14.2 Volts
Who Will Live... Will See
Old 10-16-2011, 01:49 AM
1. At least 14 volts with no load and 13.5 volts with most loads on, ie, headlights, a/c, radio.
2. I've had a battery cutoff for 4 years now on an optima battery. I cut off the battery if I will not drive it for at least 3 weeks with no ill effects.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-16-2011, 01:58 AM
