LinkBack | Thread Tools | Rate Thread |
Now in 993 land ...
Well, that was pretty anti-climatctic. Worked all weekend putting the car back together and just turned the key. Cranks over great but doesn't start.
What I checked: - Spark when cranking - none - Fuel smell - none - Fuel line disconnect at engine - no fuel - DME / fuel pump relay - checked on bench - works okay, makes contact for both solenoids - Can't hear a fuel pump, but not sure if I should be able to? It's been a while ... Not sure what I should check next? FWIW, the car sat for a year with fuel stabilizer. Please help with a list of things I can do for trouble-shooting! Thanks! George |
Now in 993 land ...
It sounds like its just a wiring issue. Is the gap on the pulse sensor correct , is that properly plugged in?
Do you have a spare dme and fuel pump relay to try ? I would just go over all the wiring. did you check the plug for the distributor and coils ? |
if it has a crank posistion sensor, (CPS) i would start there first.
JOT MON ABBR OTH
What about the alarm disconnect? Is this disabled? Could the alarm have been activated?
No spark and no fuel but the engine turns over? Something is preventing the fuel and spark. Could these be related or not? Sorry just trying to think out loud... Have you gone over the DMEs? Are all the connections fully seated? It is worth a second go around all connections, I know I have left them undone before! Heck, on my F250 one of the connections I had just verified became self disconnected in the time it took me to put the valve cover back on. Simple stuff first.
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Sounds like an electrical issue to me
immobilizer?
Now in 993 land ...
No spare yet. This is another one high on the list. I bench tested the relay and it closed both contacts. I have a new one on the way, arriving tomorrow. I disconnected an re-connected all the main connections in the connector box I feel I have good contact here. The plug on the dist is on, the coils are connected and I do not think I have them backwards. The other end of these connections are the main connection in the connector box - as said above, those connections look reasonable. Thanks! George |
Now in 993 land ...
Bill - that's interesting. Wouldn't it completely shut it down, like in not even cranking?
I do have my alarm key fob and it goes through the usual motions where I can lock / alarm the car and unlock / disarm before it will "start" (in my case now crank over). Thanks! George |
Now in 993 land ...
Fuel Pump???
Of course something random could have gone bad over the hibernation period, but most likely this is related to R&R or the long time sitting unused. We have addressed some of the connection stuff due to R&R but how about the long hibernation?
What if the fuel pump seized. Would it throw a fault for over-current and have the ECU hold back spark as well? A seized fuel pump seems something fairly likely after sitting? How could I check the fuel pump? Where is it located and how can I test it / jump power to it without destroying it? Thanks! George |
"What if the fuel pump seized. Would it throw a fault for over-current and have the ECU hold back spark as well?"
No, the DME ECM has no direct feedback from the fuel pump. It's simple to diagnose a '97 993, i.e. just connect an OBDII scanner - all the data will be there. "How could I check the fuel pump? Where is it located and how can I test it / jump power to it without destroying it?" A waste of efforts, do the easiest tests 1st, i.e. test for spark. Read here; http://www.systemsc.com/diagnostic.htm, it should be helpful.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 05-21-2012 at 08:38 AM.. |
You can use jumpers on the DME relay pins to see if the fuel pump runs. I had the same symptoms, and it was the flywheel speed sensor. To test this, I opened the DME relay(under the driver's seat) and used a multimeter set to AC voltage, across pins 47 & 48 of the large plug. iT's supposed to read 3 volts, I got zero.
Did you ever figure out the problem ?
Now in 993 land ...
I ran out of time in my garage - moving households. So, off it went to TRE!
![]() TRE found it to be a connector problem. Disassembled and re-assembled all engine electrical connection in the main bulkhead area - bingo. I am not sure why this same trick didn't work when I did it, but that's why they are mechanics and I am not. ![]() Remaining work is repairing the rear bumper from heat damage (OP had taken off the muffler heat shields), respray and reinstallation. Connect the blower, a/c, smog and off I am with an almost new car! (Trans brand new, engine rebuilt by PO)! edit: The gas was 1+ years in there and it runs fine on it. I gave it the max dose of Stabil. Nice to see how well that stuff works. G |
