964 ignition problems stumped
Hi guys I don't know if anyone can help with this but my 964 motor only runs on one side ignition module and coil, motor will start and run on one wiring harness plug to module but will backfire and shutdown when trying to run on other module alone
I replaced the igniter {ignition module} and no different, checked harness with ohm meter all wires checked out from ECM to connector plugs, If I switch connector plugs to other module and coil then that side works I thought motor should run on either side of module, wondering about my Dme ECU, The motor will run with both modules plugged in however down 45-50 hp, checked resonance valve flapper;and WOT switch, idle micro switch, distributers, rotors, running out of ideas, thanks Bob |
Seems like that's your smoking gun; you need to check the wiring upstream of that point since obviously everything downstream of that connection functions when connected to the known-good control harness.
'90C4 |
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
either one connector that works is secondary, hook it up to primary now that side works!
yes distributer belt checked
Sorry for the confusion plug that works is the primary, could the DME computer cause this? I think primary and secondary wires should connect somewhere in harness so still looking.
Thanks so much
that figures found 2 hall sensor wires disconnected repaired them but apparently still not working. Bob
A Hall sensor problem will not affect the spark signal output to either coil. Again, there's the just one spark signal output. You need to run one set of spark plugs at a time to determine the problem. Start by getting one set to run and then switch the connector from the non-running set, i.e. at the ignition module. If it again runs, the wiring from the DME ECM is O.K. Use this procedure to eliminate good components from the non-running set of spark plugs.
Dave Last edited by mysocal911; 06-24-2014 at 10:01 PM.. |
we have done that checked each side ,1 ignition module plug the primary side works engine runs when plugged into either module primary and secondary. what happened to the post from RSSCOTTY ??said he had same issue
he said bad hall sensor ,changed dizzy and problem fixed Bob |
Problem found
bad connection at igniter plug thanks for the help porterdog Bob
I'm having the same problem. When you say it was a problem in the plug, can you give any details?
Ignition woes: runs on top or bottom but not both
2010 987.2 midnight blue - SOLD I make custom engine harness for your 914-6 conversion '91 964 Targa guards red, cashmere - SOLD several 914's and loads of parts |
