964 3.6 A/C & engine bracket delete?
I have seen that many just cut their A/C bracket & put it back on and also use the original engine bracket as well. Why? Easy fix?
Must i use these or can i make my own & just use the original mounting points? Dropping a 3.6 in to a 911 from -71 will probably not allow the use of these brackets anyway. I haven't come so far just yet. But even if it will fit the plan is to make a custom bracket & delete the two original ones. Any thoughts from the more experienced crowd ![]()
you can use the oe RS engine console to eliminate the AC mount, these were unavailable for a long time but I believe that they can be purchased from Porsche again or you can cut the AC mount off, 2 ways to do it keep the upper bolt or not ![]() oe RS console ![]() oe RS console w/ oe RS lower single sheeve pully ![]() different motor same parts ![]() cut console retaining the upper bolt, stock 3 sheeve lower pulley, RS upper pulley
non-whiner
Why go through all that hassle?
Just use the console and mount from your year. It bolts right in. Here is the 95 3.6 in my 74 911. Easy.
"Too much is just enough." |
