Help, cannot get my PS fluid to stop foaming
I am trying to get the 1989 964 PS pump to stop groaning. I have pumped 4 gallons of fluid through the system and the output hose continues to pump out foaming frothing PS fluid. What am I doing wrong?
Resevoir is disconnected entirely.
Input to pump is connected to a hose and dipped into a 2 gal tank of Fresh PS fluid
Return hose is dipped into a 3/4 inch hose and dipped into a collection basket.
picture is of 4 gallons of PS fluid foaming.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-17-2021, 09:43 AM
That looks delicious !
Your set up is sucking air.
Change from a suction lift to a suction head.
Then crank/start the engine and let it run for a few seconds at a time (5 seconds maybe) then turn off. Then keep the container filled. Don't let the container run out of fluid. Do it a few times until the fluid stream is solid...
I'll just actually leave the reservoir connected and the return hose discharge to an open container.
Just run the engine a few seconds at a time not letting the reservoir get empty.
Fill it up then repeat.
If it still groans, the reservoir screen could be plugged up.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 02-18-2021, 06:38 AM
