993 not start
hello, i've 993 c2 1994 that no start
the battery has run down four or five times and I reloaded, I have now changed but does not start
immobilyzer is ok,
dme relay ok but don't have ground on 85
thank you
Old 02-13-2017, 04:21 AM
Administrator
Dmitry at Pelican Parts's Avatar
Have you checked your alternator regulator? If your battery isn't holding a charge, this could be the issue.
-Dmitry
Old 02-13-2017, 09:15 AM
yes is ok,but don't have ground out of pin 36 on the ECU
Old 02-14-2017, 04:57 AM
Bill Verburg's Avatar
'94 993 uses Motronic 2.10.1 which wants a ground at pin 36
I'd start by finding the break in the wire that prevent that.
The most common issues are related to the DME relay or the immobilizer
Bill Verburg
Old 02-22-2017, 05:46 AM
