Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Unknown sensor
This sensor or switch was dangling on its wire down on the passenger side of the engine on a 99 996. What is it and where does it go?
Old 09-07-2024, 02:06 PM
jchapura's Avatar
It is probably number 4 temperature sensor in this picture. On my 2005 C2S, it controls the engine compartment fan.
Old 09-08-2024, 03:49 AM
Temp Sensor as mentioned above. If you've noticed your fan running overtime, its because this sensor is dangling out closer to exhaust heat.
Easy fix
Simon
-1966 Lotus Elan FHC 'the project'
-1986 German Car TBD ' the ...?...'
-2006 Jetta TDI 'the daily'
Old 09-17-2024, 07:58 AM
FPB111's Avatar
If the grommet is still in the manifold take it out and put it on the sensor before you try to push it through. If you leave it on the manifold you will push the grommet through and it will land on the dark side of the moon.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 09-20-2024, 12:46 PM
