Checking interest on my custom G50 race box?
I am considering selling my G50 Race prepared transmission and wanted get an idea from everyone here as to what you think I can sell it for and to see if there is any interest to purchase it.
It is a late 80's box (88 I think) Shortened bell housing, PMS LSD, Steel synchros on all gears, light weight gears, 8:32 R&P, Billet shift forks, 993 side cover, All internal components have been Cryo/Rem treated (shifts unbelievably smooth) It has less than 50 hours on it and I will have G-Box go through it before selling just to make sure it is in the condition described and refresh where needed. It would also come with a custom mount which uses the Wevo Semi Solid motor/trans mounts and will fit 86 and older chassis. I also have a Hargett G50 shifter and linkage that would also be available with or separate from the trans and an optional 9:31 R&P that has also been Cryo/Rem treated. With this transmission I had only a 7.3% parasitic loss in HP from flywheel HP to wheel HP. (I also use special CV's with treated internals but I don't know how much this contributed to the above number) I have well over $13,000 in the box right now not including the Hargett shifter and the spare R&P. So how much do you think the G50 is worth if refreshed etc and then how much do you think I can get for it? Thanks I welcome all feedback
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
gear ratios?
The gear ratios are 1st gear- 16:36, 2nd- 19:34, 3rd- 20:30, 4th- 26:34, 5th- 23:26 All components have been Cryo/Rem treated, have steel synchros, billet shift forks, etc.
gearhead
I happened to see this box apart on the bench yesterday. The gears look brand new. For anyone who doubts whether or not REM treatment is a useful "upgrade" I can tell you that it works. This gearbox is primo.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Super Moderator
FWIW I spent nearly this doing it myself.... (estimating below)
G50 core - $3400 Guard Gears - $2400 Guard 50/80 LSD - $3000 Machine work: $600 Clutch and x-member - $1500 Totaling $11,000 NOT INCL labor, steel syncros, and std. shift forks.
I had a similarly geared and setup box that I recently sold because we moved to a G96 type box.
Bill - we used 26.5 tall tires and went to 8000 rpm. So it makes the gearing look a little different :-) (note he also said 8:32 r+p). I imagine this box was in something with similar tire size/rpm. |
So here it is w/ 8:32, still tight. Of course taller tires and a higher rev limit spread things out again.
Bill, you are right it is fairly tight but it does have the 8:32 R&P in it now and I ran the michelin sx slicks at 27.874 inches tall and shifted at 8500 rpm.
That is the best gear chart I have seen, would you mind sending me a copy via e-mail so I can work on figuring out what gearing I will need in the future either on this box or a new GT3 6 speed I am looking at. I assume it is Excel based? Also if you don't mind I would love having your input on the gearing to best match my new motor. Once you send me your e-mail I can send you the specs and Dyno numbers. Thanks Justin jwerion155@gmail.com
Super Moderator
Justin,
Quaiffe makes a nice app that can give you similar results. You can download it from their website.
At this point I have decided to keep the G50 trans as the GT2 box I was considering will require just to much modification to my cage/tube framing to get it to fit. Also I am not to crazy about the 30 extra pounds.
Super Moderator
Tease!
Outlaw 911
JWE - to really move ahead of the pack - have you looked into using the transaxel from a late 60's Eldorado? You will need to flip the ring and pinion gear, but I am guessing a cutting torch and some angle iron - it will fit like a glove.
Big bonus - you eliminate 2 of those expensive gears and the clutch pedal. Seems like a good fit for your race car. Always looking out for you. Outlaw 911 Last edited by Outlaw 911; 12-20-2009 at 03:12 AM.. |
