Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
porsher
aston@ultrasw.c's Avatar
BFG G-Force R1 application notes
I am about to install 205 and 225 R1s on my track car.
(23/31, lowered, polybronze)
Any suggestions on starting camber settings and hot pressures?
Cheers
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-20-2010, 03:22 PM
KTL KTL is offline
Schleprock
KTL's Avatar
We've run these only a short while on a friend's car- 87 Carrera 23/30 springs, adj. rear bar, 225 front, 245 rear.
We run max camber that the rear springplates will allow (with the use of the Elephant Cambermax widgets) and started pressures in the low 30's. They climbed pretty high so we settled them back at mid 30's and they seemed to do okay with wear and grip. However i'll admit said friend is one of those set it and forget it kinda guys. Half the time he doesn't know what's a good tire pressure and adjusts his driving style (balls-out sloppy lines, but still drives the crap out of the car) accordingly instead of playing with the pressures.
The fronts have the camber (-2)and caster maxed out for the stock camber plates. Shoulder wear is prominent, as is heat (shoulders turn blue when in storage). Same tire pressures. Mid 30's work well. However raised spindles and more camber are in the works to get better results up front.
Kevin L
'86 Carrera "Larry"
Old 01-21-2010, 10:58 AM
Large Registered Member
PatrickB's Avatar
subscribed...
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 01-26-2010, 12:26 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Forgot to mention i'll likely use these this coming season, so i'll post my personal experiences on my own car.
Kevin L
'86 Carrera "Larry"
Old 01-26-2010, 01:36 PM
moneymanager's Avatar
Mid 30's like they tell you, as much negative camber as possible. Great tires.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 03-12-2010, 07:41 AM
porsher
To answer my own question
32 F, 34 R hot
-3 neg F and R
79 928 Race Car
Old 03-12-2010, 08:43 AM
Yeah ,I remember with my old r1s the pressure would go raelly high after the first run group. Nitrogen is supposed to help the stability of pressure though a lot of tire shops and off road chassis shops( shocks) have this.
Old 03-12-2010, 10:56 AM
