What good is handling in corners if you always get passed on the straights?
If anybody watched the Bathurst 12 Hour race last weekend, this is exactly what the Audi guys were saying. They were faster on the top of the hill [curvy sections]. The Mercs, McClaren, Bentley's, and GTR would then blow by them on the long straight. The "balance of performance" was there with roughly equivalent lap times when qualifying, but in race conditions they said they didn't have much of a chance to win. Of course they weren't there to have fun, they were there to win.
1979 911 sc coupe |
Chad
That was great, having owned a 65 vette for many years, before it was stolen, it was great to see the two of you playing your strengths and weaknesses.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
I think all of this back and forth has well established a better driver almost always beat a "faster" car. That being said, hp ain't everything. The OP showed a 1960s muscle car vs. a Porsche. The Firebird had better show up with TONS more hp because a car like that was never designed to compete on a road course. A nose-heavy brick with a solid rear end and non-boxed frame is probably doing quite a bit of flexing trying to negotiate those corners. And if handling doesn't matter, look at the giant-killers Lotus and Porsche of the 1950s and 60s beating Ferraris and Jags.
HP doesn't mean too much if you can't use it. How effectively is that getting to the ground? TBD or LSD used? Center of gravity, wheel/tire size, etc.? If traction doesn't matter, then what about Audi in the early 80s or Mitsubishi and Subaru in the early 2000s? This is one of my favorite examples, EVO vs. Z car. On paper the Z is lighter, more hp, and has better aero...but the EVO is quicker due to better traction and handling. Sports Car Comparison - 2011 Nissan 370Z vs. 2011 Mitsubishi Lancer Evo GSR And one of my favorite "better driver" examples, he makes it look soooo easy. The dude is fearless: https://www.youtube.com/watch?v=eSJ-HzNWJGM
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims) |
jadewombat~ that last one is very similar to this one of Sabine Schmitz in a VLN race. She knows the track and car so well, and knows no fear, even in a light rain.
https://www.youtube.com/watch?v=ufzdL1JaEKM
1979 911 sc coupe |
914 Geek
To turn the OP's question on its head:
What good is HP, if you always get passed in the tight sections? --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I wish I could find some youtube videos of the original Trans Am race series when the two classes ran together and the little Porsches in the lower class regularly harassed the bigger cars in the premier class.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I have a 211HP 2.5L short stroke, single plug, 46mm PMO's. My car weighs ~2100 pounds. I'm not sure what those muscle cars weigh.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
In the arms-race of hp where american V8s are achieving higher and higher hp numbers, again, it's important to understand useable power. My buddy's Datsun 280 with an LS crate motor swap and limited-slip, he spins out near 10:00. I would've probably done the same thing. https://www.youtube.com/watch?v=iAz3KXl2IfA&feature=youtu.be
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims) Last edited by jadewombat; 02-17-2016 at 07:09 AM.. |
The smaller generally catches up, but rarely passes. He is just stuck behind. And on the case the smaller does pass, he often gets passed right back on the next straight. Based on the evidence offered here, it's evident that power trumps weight, which is probably why pro drivers use huge HP, and not 50hp featherweight go-karts. The post below basically confirmed all this from a professional point of view: Quote:
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 02-17-2016 at 09:53 AM.. |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Chad
As you mentioned the type track has a lot to do with it and it's power to weight not horsepower. Then it's stay in the other guys mirrors, look for his weak point and be ready to pounce.
914 Geek
--DD
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Sugarwood, in races with cars of equal horsepower, most of the passing is done in the braking zone before the corner.
This is equally effective for small cars attacking high hp cars, as well as any car of equal hp. It comes down to race-craft. All things begin equal, HP just gives an advantage to the lesser skilled driver. If you want to pick the best mix of hp and weight, as has been said, a big factor will be knowing which tracks you will run at. Lemans and Daytona both reward big hp due to top speed more than acceleration. Other tracks like the old formula one track at St. Jovite that I drive on rewards perfect lines more than hp, because so much of the track is the twists where you can't take advantage of any hp advantage, and, in a race, a good under hp driver would time the pass and track position to take away the high hp driver's drive. Likewise the high hp driver would try to do the same to take away the lower hp driver's momentum. What I find sad for professional racing is that at one time, the race organization used to leave it up to the teams to decide how to go fast. Now with balance of performance rules, they keep it so close that it is rare that you will ever see these old underdog battles. The reason that teams like Shelby and Pensky opted for big truck engines back on the day was that they were more likely to last to the end in endurance races. For sprint races smaller engines gave the advantage of lighter weight and sometimes at lower hp, but the driver and engine had to work a lot harder. Then there is the other factor of power to weight. Big hp in a heavy car vs. lower hp in a lighter car, but both with the same percentage of power to weight is a different variable again. I will agree with you that it is easier to go fast with a high hp car, but I will also state that you don't learn much. When I road raced motorcycles I started with a relatively high hp 4 cylinder 500cc two stroke. I was great at out accelerating and out braking the competition. It wasn't until a few years later when I did an 8 hour endurance race on light a 600cc single cylinder bike against the higher hp super bikes on a twisty Blackhawk farms circuit that I actually learned to go fast.
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 02-17-2016 at 02:50 PM.. |
F=MA A=F/M acceleration=force/mass torque is a twisting force that causes rotation hp is calculated from torque, so for now lets ignore HP given hp is calculated based on torque. so A=torque/mass so, a 2000lbs 911 with 200lbs-ft torque will accelerate at... A=200/2000= 0.1 (lets not worry about units) Now, lets look at a 4000lbs, 400lbs-ft Mustang. A=400/4000=0.1 So more torque will not accelerate faster (all other factors equal). What you need to look at is power to weight. Both above cars have an identical power to weight, so identical acceleration. Now, nothing is quite this simple. gearing, drag, lateral grip, breaking, car setup, driver, tires, gears... etc. all play into it. Some tracks also have corners that are far more open to allowing a pass, and very limited straights. Again, where I go, handling cars, not power cars, rein supreme. Mind you, a handling/cornering being the same, the car with more power will win. But than this is no news. Quote:
In modern racing, to win you need cornering/handling, and power. Quote:
Mark Donahue, who raced the 917-30, was once asked how much hp is enough. His response was something to the effect of "I have enough hp when I can spin my wheels from corner exit to corner entry on the straights." What is super cool about the 911, and a small part of why why many of us here love them at the track, is that they tend to punch above their weight when driven well. The rear engine both allows later braking, and earlier power on after the throttle. As demonstrated in some of the videos, this allows the car to "punch above it's weight (power)".
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 02-17-2016 at 04:28 PM.. |
Thats a great write up
Here is one of my favourite videos. At the beginning he dices with a similar car to the one he is driving but with obviously more power (or maybe he is just running amor defensive line and not getting as good a run off the corners due to the heat behind??) . You can see the give and take. After the midway point of the video things get interesting. (would have been even more interesting if there was a rearward facing camera to see the pressure he was under from behind as he was trying to both drive defensively yet aggressively enough to get the car ahead). Described as Patrick Long in a car 1/2 the horsepower of the 935s he dices towards the end. (that twice the hp, TWICE! so Long's 300 hp vs. their 600hp. or maybe 350hp vs. 700hp???) I'll go out on a limb and suggest that Long has more skill while those 935 drivers as well as that duck tailed RSR at the beginning all have more hp. Professional driver vs. not professional drivers. EDIT: I just realized that this is a different video. I'll post a link if I find the one form 2015 that I meant to post
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 02-17-2016 at 06:25 PM.. |
Racer
Let's not forget that most of those guys are out there to have their car seen and not drive them anywhere near its potential. Patrick, on the other hand, is able to drive the car close to its potential without undue risk.
It's kind of like watching Canepa be a crazy man and pass all the cars in his races except for Patrick is not crazy.
I'll bet that they use all of the gas pedal though
Racer
Maybe. But what is the boost set to? Probably a very conservative BAR setting. Look how easy most of them are taking it in the corners. It looks like a Sunday drive!
