Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
sugarwood's Avatar
How do you correctly navigate a 90* turn?
When driving on remote back roads, I encounter a hard 90* turn, but not in an intersection. I never feel like I nail this downshift & turn. I need to slow down a lot, enough that 2nd gear is the correct gear to power out of the turn. Yet, let's say you're approaching this turn at 55 mph. It feels too fast to shift into 2nd gear. I feel like I shift into 2nd gear in the middle of the turn, which I know is wrong. What exactly is the correct procedure? Slow in a straight line until I am in 2nd gear territory, downshift, then take the turn? If I do this, I almost feel like I am slowing down too much. I feel like I can take the turn faster than the speed needed to be in 2nd gear. Or at least, the timing is off.
1986 Bosch Icon Wipers coupe.
Old 09-08-2016, 04:20 PM
Cajundaddy's Avatar
Depends on the corner, what leads into the corner, and what follows the corner. Lotsa different ways to do a 90.
One example of a typical street corner at a race track with a flat surface:
I expect the apex speed in a street car to be about 45. If I go through there at 47 I will end up in the dirt or my PSM will flash engagement reminding me I am driving foolishly. To make the most of a right 90 corner I will enter from as far left as possible to open up the radius a bit, brake in a straight line to about 50mph, turn in for a late apex and allow tires to set and scrub a little speed on my way to the apex. Once I have sighted my track out point I will add gas hoping to be full throttle at or shortly after crossing my late apex point as I unwind the wheel on my way down the straight.
For a 45 mph apex I would normally heel/toe downshift to 2nd gear in the braking zone so I will get the best launch out of the corner. If it were possible to carry third gear through apex above 4000 rpm I would use 3rd and avoid the downshift/upshift inputs. The tradeoff is max torque vs max driver focus.
This is a common 90 corner method at a race track. There are others. I don't recommend trying this and going "all-in" at your next canyon carving session on public roads.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 09-08-2016, 05:31 PM
sugarwood's Avatar
Let's say heel/toe is not an option, and you can't brake and downshift at the same time. It seems like there is a "dead zone", where I'd have to slow down too much to get into 2nd, but taking the turn in 3rd is too high.
Old 09-08-2016, 05:56 PM
Cajundaddy's Avatar
With my students whose h/t is not ready I recommend brake > downshift > turn in > gas. That gets your entry speed down so 2nd gear won't be a 7k zinger. Release the clutch while still in a straight line to avoid upsetting the car. The solution to the "dead zone" of course is heel/toe. This smooths the transition to 2nd gear into one fluid motion. A very useful technique to make the most of corner entry.
Old 09-08-2016, 06:42 PM
Racer
winders's Avatar
You are on the street. Of course there is going to be "dead zone". You can't drive on the street like you would on the track.
I know many racers that don't heel/toe and there is no dead zone for them on the track.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 09-08-2016, 07:49 PM
Cory M's Avatar
Google "Scandinavian flick"
Old 09-09-2016, 10:02 AM
sugarwood's Avatar
Chicane is not a 90 degree turn.
It's like a swerve, and certainly not reducing speed to 2nd gear.
I find them to be very different.
Old 09-09-2016, 05:19 PM
Racer
winders's Avatar
Often a chicane is two 90 degree turns one after the other.....but like Charles said, whatever. You need to get a clue before you dismiss information from people that know a hell of a lot more than you do.
Scott Winders
PCA GT3 #3
Old 09-09-2016, 08:20 PM
Functionista
manbridge 74's Avatar
True repentance is actually 180*.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-09-2016, 09:25 PM
Emo993's Avatar
If your not sure of the 90. Always get braking done before turn in (with H&T down shift)....late apex...then full power. Best, Mark
Old 09-10-2016, 03:33 AM
Vintage Motorsport
RichardNew's Avatar
If you really want to have fun try an early car with trailing throttle oversteer.
Go in really hot and lift off the gas. The rear will break loose. When the back end gets to the angle you want jump back on the gas and accelerate.
Trailing throttle oversteer is your friend.
Richard Newton
Old 09-10-2016, 05:07 AM
sugarwood's Avatar
First, there is no need to be a dick.
Perhaps I need to get a clue, or perhaps I have a different perspective and context than you.
The definition of chicane from Wikipedia says "One form of chicane is a short, shallow S-shaped turn".
Now, maybe there is no standardized definition of a chicane, and maybe some are 90 degrees, and that would explain the disconnect.
I have driven the "bus stop" at Watkins Glen, which I was told is a "chicane".
Look at the photo, do you see a 90 degree turn? I do not.
Navigating this chicane was nothing like the turn I originally described in this thread.
Here is a photo called "Le Mans Chicane".
Do you see a 90 degree turn?
Here is another photo titled "chicane", by the Institute of Transportation Engineers.
Old 09-10-2016, 06:29 AM
sugarwood's Avatar
Street racing forum? For crying out loud, I am talking about correctly taking a sharp turn where I am well within the speed limit in either gear.
What a sanctimonious prig. I am not doing anything even remotely resembling street racing, and frankly, do not appreciate your overtly disingenuous accusations.
Old 09-10-2016, 08:30 AM
non-whiner
mreid's Avatar
Sideways
"Too much is just enough."
Old 09-10-2016, 08:57 AM
Racer
winders's Avatar
The Monza chicane:
Scott Winders
PCA GT3 #3
Old 09-10-2016, 10:25 AM
Emo993's Avatar
Well, maybe Monza didn't like it either as a chicane.....it's being removed for 2017.....
Old 09-10-2016, 12:44 PM
sugarwood's Avatar
Yea, we've already got that covered.
Old 09-10-2016, 01:12 PM
Racer
winders's Avatar
Dude, you deserve no help......
Scott Winders
PCA GT3 #3
Old 09-10-2016, 01:30 PM
gearhead
I suggest you take the turn 5 quarts low on oil.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-11-2016, 07:27 AM
Originally Posted by matt monson View Post
i suggest you take the turn 5 quarts low on oil.
:d
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 09-11-2016, 09:32 AM
