Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
whatudrivin's Avatar
I am in on this one. I cant wait to see some more updates and pictures. Amazing work indeed.
Old 01-06-2012, 01:07 PM
porsche powered mid-engine double cab
Thanks.
Here are some shots of the custom oil tank I am mocking-up for Seth to build.
The tank will hold a bit over 3.5 gallons and will fill and vent from a opening flap cut into the outside of the truck.
Here is a shot of the rear support for the hitch and shock mounts from the last visit to Seth at Twisted Minis.
Some parts for the oil system, Fluidyne front cooler that will be cut into the front bumper.
Old 02-06-2012, 11:13 PM
TurboKraft's Avatar
Bravo! Simply awesome.
To your fabricator: congratulations, sir! That exhaust -- usually we find that the simpler it looks, the harder is was. If it looks easy, it wasn't.
Great build.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 02-26-2012, 03:25 PM
Bird. It's the word...
Fishcop's Avatar
Such an epic build!
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-01-2012, 02:02 AM
Thanks guys for the kind remarks.
Fishcop, I have been following your thread in the bodywork forum and am using it for technical and mental preparation for when I tackle the body and paint on the d.c.
Turbokraft, I am sure Seth will appreciate your remarks as one pro to another, I know he puts more effort into the build than my compensation can cover, but thats what talent and integrity can make people do.
I have been working on some small stuff until Seth and I can get the dry sump tank built.
The seat base and back will get foam and vinyl covering.
Old 03-11-2012, 06:11 PM
Here are some shots of the dry sump tank, test fitting before Seth does the final welding.
It is a stock Patterson tank that has been "adjusted" to fit in its new home.
Old 05-14-2012, 07:16 PM
Here are some more parts to the oil system, the vent and fill will be cut into the side of the truck and covered by a vented teardrop blister thing.
Seth is metal forming the blister from the rough shape made by pressing thin aluminum sheet in a wood and epoxy form I made.
Old 06-01-2012, 07:18 PM
I found a photo of the form before I poured the epoxy to make the negative part.
Old 06-01-2012, 07:32 PM
Some more progress on the vent box.
I still need to cut some slots in the cover for the oil breather tank.
Old 06-25-2012, 10:11 AM
A little more progress to show.
vent slots cut into blister.
oil fill and breather tank filter.
dry sump tank bolted in and vent/ fill hoses plumbed in.
Next up is front oil cooler fabbed into front bumper.
Old 07-11-2012, 05:46 PM
redstrosekNic's Avatar
Fantastic work!
Dustin
Old 09-09-2012, 07:17 AM
Thanks!
Here are some shots of the front cooler, lots more to be done to this part.
I have also been working on the electrical system, the dme is mounted with rubber standoffs.
Old 09-26-2012, 09:54 AM
Send a message via Yahoo to Lukesportsman
Nice RS bumper on a van
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 10-24-2012, 09:26 AM
Thanks Lukesportsman, I just wish I could have made it as light as a RS bumper, but in a early type 2 you need all the help you can get!
Here is some cable shift action.
Mostly done , just needs some detailing.
Old 10-28-2012, 03:40 PM
Some more shots of the cable shift contraption, now the finished version.
Old 11-03-2012, 04:18 PM
Max Sluiter
Flieger's Avatar
Very cool.
Old 11-05-2012, 08:34 PM
I cannot wait to see the finished product! It is very cool following the build with pictures, though
Dustin
Old 11-07-2012, 05:35 AM
Thanks again for the encouraging comments.
Some more progress on the electrical front.
I am adding six switched and six always hot fuses in the new engine bay, I would like to do a complete re-wire in the future but this should work for now, the stock vw wiring still works but has a lot of unfused circuits.
Old 11-11-2012, 07:53 PM
Some more slow but sure progress, the electrical system is finished and I ordered the last of the oil system -16 fittings.
I ordered four fittings and five feet of hose to get the dry sump tank hooked up so I could put the engine in.
All the wiring will be wrapped after start-up, keeping it open till tested under power.
The seat base in position, 1/8" clearance to idle valve.
Working on the engine tin, front mostly done.
Old 02-09-2013, 10:15 AM
Epic!
1972 911T/S MFI Survivor
Old 02-14-2013, 03:17 PM
