Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Audi V8 in a 924.
Hi All,
I am currently working on swapping a Audi 4.2 V8 into my 82
Currently working on getting everything squared in place then building engine mounts and Oil pan.
924.
Old 01-09-2017, 06:50 PM
Toofah King Bad
Rasta Monsta's Avatar
Wow, please bring this thread over to 924board.org... you'll get lots of love over there.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-12-2017, 01:51 PM
Most certainly will! Thank you for the kind suggestion ^_^
Old 01-12-2017, 05:07 PM
Toofah King Bad
Engine swap subforum is here: http://www.924board.org/viewforum.php?f=2&sid=b68de0e34a176e6879926658d857c593
Sent from my Amazon Jem using Tapatalk
Old 01-13-2017, 07:03 AM
jadewombat's Avatar
Wow! Awesome stuff. I "think" you'll need a bigger or an additional radiator though. The RS4 I had a few years ago got up to operating temperature within like a minute after I started it and always seem to have a great amount of heat up in that area under the hood.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 01-27-2017, 07:48 AM
Thanks Jadewombat its been a fun project so far! I was thinking of the heat, so I went with of a triple core 26x19 radiator. also using a 19" dual speed fan. ^_^
Old 01-28-2017, 10:56 AM
jadewombat's Avatar
If the fans are running all the time and you find you need more cooling, maybe some downward scoops in the hood. It would also improve downforce on the front end.
The Dodge Hellcats use this also. They made street cars that are made to run flat-out for a full 20 minutes.
This green 911 is/was on here from a few years ago and the owner fabricated the downward scoop. I've seen similar on 944s also.
Old 02-03-2017, 07:18 AM
I will most certainly keep this is mind, I do appreciate the information.
Old 02-23-2017, 12:13 PM
Any updates?
What year V8 is it? ABH/ABZ?
Curious what clutch fly wheel combination you were planning to use
Old 03-17-2017, 11:05 AM
Originally Posted by crave View Post
Any updates?
Hi Crave, nothing new yet, I have not been able to go up and work on her. I will be going this weekend, so ill have updates then.
I will be using the duel mass flywheel and pressure plate from the 2.7T Audi, then a Mazda/Ford 2.3L turbo clutch disk. Year engine is 2001 ABH If not mistaken. I will double check that number when I go home. Engine was pulled from a A8L with everything on it, paid $900 shipped.
Old 03-19-2017, 01:27 PM
Nice. That should be an AUX engine, I did not know they might fit the chassis. I have 2 D2 Audis, great cars. You can get a whole car with a dead trans for $1000 or so and sell a bunch of parts to recoup costs. The engines are pretty robust although can get carboned up, maybe due to cheap gas.
The stock ECU is mated to the cluster and pared with the ignition keys so you may have to deal with the immobilizer if you are running the stock ECU.
-Joel.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 03-20-2017, 05:42 AM
-Joel.
Was looking over my paper work, yes, AUX is the correct code, After I get everything put into place I will be rebuilding the top end and new rod bearings.
ECU is already been reworked, so the VAG/IMO systems and the ties to the Auto trans have been removed.
Thank you for the information, If i blow this engine up I will give you a call ^_^
Old 03-20-2017, 12:21 PM
Will the bell housing bolt straight up to the 924 Torque Tube? They look compatible...but what kind of bellhousing is on the back of the V-8? Is that the one off of the 924 engine?
Old 03-21-2017, 04:06 AM
Toofah King Bad
931 bellhousing bolts to some audi v8s, but requires clocking the torque tube.
Old 03-21-2017, 05:38 PM
Hi, The Bellhousing is from a 924 turbo, with a Audi V-6 Spacer welded to it so i have more bolt holes to fit to.
Old 03-22-2017, 12:42 PM
You are 100% correct, the stock torque tube is coming out and a 944 one in going in. I have a plan to turn it slightly to allow the V8 to sit flat.
Old 03-22-2017, 12:43 PM
Does this all fit under the hood or you will have to modify it?
Old 03-31-2017, 12:20 PM
Believe it our not, yes. ^_^. I am having an Oil pan CnC out of Aluminum. to aid in the clearance.
Old 04-05-2017, 06:16 PM
Updates
Hey Friends, Sorry i have not been able to do anything new with my V8 swap. In December I will have some good time off to do some work my swap ^_^ ^_^
Old 07-11-2017, 08:40 PM
hope you never get in an accident, those long members look pretty fragile w those mods.
Old 07-13-2017, 12:00 PM
