Re: Re: Details -- Details
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
I can't remember about the sun visors, but if there was a light in the trunk, it didn't light up.
One other note. When the deck lid was raised, there were two lights built into the lid, but not in the usual way. They were built into the "end" of the lid, not on the underside if that makes sense. They were such that they would be touching the rubber lip on the body when closed. Is that right? -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
it did say KG in the aluminum tag up front.....
-Chris
Starkey suggests that the luggage compartment light, clock and sunvisors were deleted from the light-weight models. I didn't see them listed in the ebay add's listing of options. Looking at the white 406, I noticed that it too has visors, as well as a clock, so I guess it's the same either way.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 06-29-2006 at 02:05 PM.. |
I guess at the end of the day, a really good 911RS replica would be worth quite a bit of money, although I doubt it would be worth a whole lot more then it would cost to replicate, so maybe +/- $60K - $100K. If that's where the bidding stops, then it would sound like the "invisible hand" of the market-place will have spoken. So then this auction would wind up like many others with the seller having unrealistic expections about what his car is worth.
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Guys, This is a TOURING model with lightweight mods done by some one at some place in time. So discussion about lamps, visors, seats, and all the bolt on parts, etc is moot unless the car would be restored to all original touring spec as per the records (as printed in konradshiem's RS book). Untill the Dr. allows more inspection, there are no visual clues other than what has been photographed already
But then again, we have to make sure it is a real RS, right?
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Yes it did have sun visors. and clock.
It had the two small lights in the ducktail at the bottom. Was that the same as what chris was talking about. Another note He Demostrated the Emergency electric cut off. When he turned it off the clock was still clicking is that how they work?
Tim. 1988 911 Carrera. Silver. 1973 914 Metalic Blue. 2012 Cayenne S |
Re: Re: Re: Details -- Details
Porsche probably has a back stock of "KG" VIN tags that they used up before switching to the "AG" tags. But yeah, this car is before the change over to AG. They did the same thing placing a back stock of optional early 911 parts on late 1973 911's (to get rid of them) before the change over to the '74 big bumper style. Last edited by Carl Bauer; 06-29-2006 at 02:23 PM.. |
-Wayne
-Wayne
-Wayne
3 restos WIP = psycho
I thought it was only the part numbers that you can see under the car? The cast dates are hidden by the fan shroud.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
On the engine case itself there is the round date "stamp" that is molded in. The transmission has the same "stamp"
Matching numbers? someone had to have the original drivetrain (and that HAS happened before- a car built around a RS motor and trans!) OR a set of german # stamps
FWIW, here are some pics of my vin and front plate. The car is a 72T w/ original paint.
Jay '08 E350 Wagon '74 914 gone '72 T gone |
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 06-29-2006 at 05:04 PM.. |
Ayo Irpin, Ukraine!
So, it looks like the VIN plate changed to the 4 row for 72 and the font style of the trunk VIN changed too. Also looks like the VIN plate area got a little larger too. The very blurry photo of the "RS" VIN plate clearly shows the three row which would be incorrect but, could be a replacement.
Were the trailing arms steel or aluminum? I think only the front crossmember was alum. for the 2.7 RS.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
The RS has steel trailing arms but with a very unique gusset welded on for strength. The front cross member should be AL.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
Well, there seems to be a lot of confusion here, so I'll throw in my 2 cents, and see if I can confuse more.
M471 (lightweights) AND M472 (Touring) BOTH were manufactured using the thin sheetmetal until supply exhausted. I have seen with my own eyes, #411, Touring/first series, FAIL the 'push your thumb into the center of the roof' test, leaving a very uhappy owner with a dent in his roof. When the thin sheet metal supply was exhausted has been the topic of ENDLESS debate; some say car #1036, some say earlier, some later. My RS, Touring, #1248, restored in Germany as a M471, has a 'birthdate- of 4/18/1973. Per Konradsheim's book, this is right around the date where "thin sheet metal used until supply exhausted." Who knows which cars received which panels if ANY, after the chassis no longer needed to be individually weighed. There a MANY little 'tells' to ascertain a REAL RS from a total fake, or clone. Brian has pointed correctly pointed out MANY of them. On my car, for instance - as a Touring, it came with a STEEL space saver spare, with a Bridgestone tire. The tire, of course having never been used, is date stamped 4/73. The 300khm speedo, correct for my manufacture date, is also date stamped on 4/73 on the back, and on and on it goes. The EBAY car, because of the dupe chassis number, is very suspect. The owner's curt and defensive replies to emails ONLY makes MORE SUSPICIOUS. Without verification of the production number, and a complete and thorough search of all the little RS 'special things', along with a 'date stamp' check of all the places where one could check, we'll probably never know. AND, even then, A REALLY REALLY GOOD FAKE MIGHT PASS THE TESTS....
1972 911S (2.7 RS Spec engine) 1973 911RS (2.8 RUF rebuild) 2014 GT3.1 Now available... 2018 GT3.2 Miami Blue, 6 spd... ![]() ![]() ![]() |
