Oh Haha's Avatar
Porsche Crest Option code for LSD in a 915?
Anyone know the option code for LSD. I believe my SC came with it but I suspect it needs replacement or adjustment. I have no experience with this type of setup. I'll be pulling the trans to look into the 5th gear issue discussed earlier this week. While I am in there I would like to check the LSD out.
Thanks,
Pacific Blue
Wayne
Old 10-11-2006, 05:43 PM
all i know is there is a 12 stamped among the numbers on the rib under the diff if it has posi from the factory.
206 637 4071
Old 10-11-2006, 06:10 PM
Goth's Avatar
The option code on my 84 Carerra w/LSD is "220". I think the code should be the same for your SC. BTW; it also has the "12" stamped on the bottom of the trans case as mentioned above.
Hope this helps
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 10-11-2006, 06:17 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Goth,
Do you happen to have a picture of this "12" where it is stamped on the transmission. I'm pretty sure that I'm not one of the lucky ones, but I'd like to make sure. My car has surprised me in the past. I do not fell like placing it on jack stands just to try the rotation test.
Thank you,
Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-11-2006, 09:30 PM
On the bottom raised surface....looking up...placed between transmission type number and serial number you should be able to see "12"....
915 limited slip???
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-12-2006, 05:38 AM
Bill Verburg's Avatar
Hayden posted these a while ago
No lsd
w/ lsd
Bill Verburg
Old 10-12-2006, 05:44 AM
MattAlpha's Avatar
Very nice, thanks guys!
Old 10-12-2006, 07:44 AM
Grady Clay's Avatar
OK guys,
What is the difference between M220 and M221 (BA p. 256)?
M220 – “Locking differential”
M221 – “Porsche-locking differential”
(There is the same distention in the Kindel list.)
I have seen LSD transmissions with an “11” in place of the “12”. What is this?
Best,
Grady
Old 10-12-2006, 10:31 AM
the first character is the type - G is a Getrag
the next 4 are the version -G5001 is an early Getrag 5 spd g50/01
1 as the next digit means open diff, 2 is M220 option lsd G50012 is a 40% lsd diff.
the next digit is the year
the last 5 digits are the serial #
can't find any info about M221 except it's in there starting w/ the '87 Getrags
Bill Verburg
Old 10-12-2006, 11:40 AM
Oh Haha's Avatar
Mine is stamped:
915/62 731 4913 No "12".
Stupid question: If I don't have LSD, why would have I been able to leave two strips of rubber between first and second? Before flaming me for speed shifting, this was before I blew out 2nd doing this. I don;t drive like this anymore.
Pacific Blue
Wayne
Old 10-12-2006, 03:39 PM
sometimes you just get lucky
Bill Verburg
Old 10-12-2006, 05:02 PM
Oh Haha's Avatar
But I'm married.
Oh, c'mon, you were thinking it.
Thanks for the info, Bill. One less thing I have to worry about inside the tranny.
Pacific Blue
Wayne
Old 10-12-2006, 05:37 PM
You might have gotten lucky and had a PO put in an LSD with a prior rebuild. Here's a simple test that will tell you for sure what you have, regardless of option codes or transmission stampings:
Jack the rear of the car up so both wheels are off the ground. Ebrake off, car in neutral. With your hand, spin one of the rear wheels. If the other wheel spins the same direction, you have an LSD. If they spin opposite directions, you have an open dif.
With any luck, maybe you'll find something from GT in there.
Chris M
1985 911 Carrera w/ 3.6
Old 10-12-2006, 08:56 PM
Somewhere in the Midwest
MotoSook's Avatar
I've got a 915 with the stamp: 915/62 AT 731 3506
The output flanges spin in opposite direction. I'm assuming it's sans LSD, but does the 731 mean the 7:31 R&P? And what does the "AT" mean? I've never seen the "AT."
Old 10-14-2006, 11:44 AM
there were 2 systems used thru '81 and '82 up
for yours this is the trans id
731 3506
7- type
3- version
1-model year 1981
3506- serial #
if there was a lsd it would rear 915/61 12 731 3506
I have no idea what AT means
Bill Verburg
Old 10-14-2006, 12:19 PM
MotoSook's Avatar
Thanks, Bill. Another trusted source has never seen the AT either.
Old 10-14-2006, 12:21 PM
Maybe you left two black stripes because you were pointed straight ahead ??
...might be a different story trying to put power down in a high-g, tight radius turn....
- Wil
Wil Ferch
Old 10-14-2006, 06:38 PM
Yep, that would be my guess. With an open dif, the power wants to take the path of least resistance. With the car level, pretty much equal weight on the rear tires and the same tires on each side, it's not impossible to spin both wheels at the same time. Both tires present the same load to the diferential, so they should, in theory, spin at just about the same time.
Now, if there is an imbalance, then one wheel will spin while the other doesn't. Like, one tire loaded in a turn and the other unloaded. Or one tire stuck in the mud and the other on the ground, a la My Cousin Vinnie.
Chris M
Old 10-15-2006, 08:47 AM
MotoSook's Avatar
I'm having a hard time believing that an open diff. will allow both tires to lay down rubber at the same time. Even on a perfectly level surface there will be an imbalance in the torque and grip at each wheel. When that imbalance occurs (likely at the initial application of power), the power will be tranfer to the slipping wheel (or wheel with less traction) and stay there.
Old 10-15-2006, 09:03 AM
I can't believe all the responses, with all this going round-n-round.....
....just jack the rear up and hand spin one of the tires...see what happens on the other side. If it spins in an opposite direction...there's no LSD or the clutch pack has worn even if it WAS delivered as LSD. If it spins in the same direction, you have LSD and a functional one at that.....
- Wil
Wil Ferch
Old 10-15-2006, 09:14 AM
