Stahlwerks.com
air injector plug size
Can someone give me the specs on the size plugs that go in the air injector holes on my 3.0 heads?
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Irrationally exuberant
The plugs are M10x1. Link to thread on air injection plugs.
-Chris |
Stahlwerks.com
the best ones are aftermarket 914 rear caliper plugs. hex head, and a flange. pelican should have them.
-Chris |
Stahlwerks.com
Dooh, no fine thread plugs on there, I'll get them from Wayne,
Thanks Guys!
S caliper bleed valves are the same size. I had to order the tap to straighten out my front brakes from mcmaster.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer Last edited by Tim Walsh; 04-22-2003 at 11:23 AM.. |
Forced Induction Junkie
Chris,
Hey neighbor! Where is your "local metric hardware place"? Enquiring minds want to know! :-)
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Author of "101 Projects"
-Wayne
I know my 993 calipers and 930 caliper bleeders and Carrera brake lines are all 10x1.0 if that helps.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I do know that 10x1 is the correct size for the bleeders. I don't know the correct size of the injection plugs though.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
I've plugged the ports in a 2.7 motor and an '81 SC motor with 10x1.0 plugs.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 04-24-2003 at 07:33 AM.. |
there are perfect plugs available for 1£ a pop from http://www.type-911.co.uk/
Pictures: Stupid guide of fitting emmision plugs in three steps...
Thank you for your time, |
