Well, after a bit of a delay ...
Here's the schematic and replacement parts list for the Bosch 0.227.300.004 6-pin CDI unit, cussed & discussed at great length ... and used on SCs & Turbos thru '89!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 07-05-2007 at 12:19 AM.. |
Great work Warren. This is what makes this board as great as it is.
Tim
1986 911 Cab 2008 Audi A6 |
Somewhere in the Midwest
Excellent, Warren!
Irrationally exuberant
Awesome!
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Now somebody post a circuit board pic
- That's defintiely $400 worth of parts isn't it.....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Warren,
Thanks! Here is the thread on the Bosch 3-pin. It has a wiring diagram also. Perma-tune CD or Bosch CD? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Senior Member
Very cool. I just wish I understood.
Which of those parts fails, typically, when a Bosch CDI unit stops working?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I would rather be driving
Very Nice Warren!
Superman, I think the Thy might have the best chance of going bad. of course, there is always the chance of a blow cap, diode or resistor.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Component replacement and checking is not that hard on these older analog items. You could take a course at a community college and I'd bet 1 course would do it. This also helps stave off Alzheimer's if you are turning gray... If you screw it up, then send it in for re-grooving by a pro.
Great work Warren...
Another question - what about the pin-out for the 6 pin connector? Is there any place I can find that? thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Here is the pinout looking into the connector with the mounting flange sitting on the hand or table ...
. 31/1 ... TD ... 31d . A . . . . 15 . . . 7 ============== 31/1 -- Power ground 31d -- Signal ground [green coax shield] for trigger signal 15 -- +14 Volt power lead 7 -- Trigger signal from distributor magnetic pickup coil TD -- Tachometer Drive signal A -- +460 Volt pulse output to coil
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 01-26-2005 at 11:08 AM.. |
Here are some resources worth reading if you are a bit rusty on the theory of operation ...
http://www.irf.com/product-info/thyristor/manual/scr_manual.pdf http://www.st.com/stonline/books/pdf/docs/4347.pdf http://www.st.com/stonline/books/pdf/docs/5201.pdf
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
And, here is an application note from RCA that may be helpful ... after much difficulty with pic uploads [never copied the image code to edit window -- multiple attempts] ...
And, here are the last two pages of AN-6288 ...
Crusty Conservative
I nominate this entire thread to become a PP Tech Article. Invaluable information from Warren as always, Thanks!!!
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Here is a bit of design info from GE Semiconductors Electronic Data Library #400.6 on the single-transistor inverter as used by Bosch in our CDI units:
Truly awesome. Adding to the knowledge bank, Warren!
Andy |
Randy,
Thyristor is an early name for a Silicon Controlled Rectifier (SCR). The name is a combination of Tryratron tube and transistor. The beauty of an SCR is that a miniscule current or pulse can turn on a huge current and it stays on until the source current drops below a certain threshold. This is used in CDI and household dimmers. Best, Grady
You're right -- I was thinking of thermistor.... Dunno whether to blame it on age or elapsed time since I've done any electronics work... I'll kill that post.
