Finally in from Germany. My next door neighbor's nephew is a car nut/engineer over in Germany (the Eifel (near the Nürburgring)). He was able to source the elusive BA7s based 3W/12V bulbs.
This weekend I'll start to conduct some simple tests to present to the crowd. The following tests will be conducted for new Bosch 2W bulbs, new 3W bulbs and my 20 year old OE bulbs : - Individual current draw - Light meter readings (In and/or out of guage??) - Visual impressions/pics I'm trying to decide on an appropriate power source for the test as I'd like to conduct indoors. I'll also have to source a light meter...I think dad has an old german one .From there we can attempt to calculate load capabilities of the dash harness. Cross your fingers.
Warren & Ron, may you rest in Peace. |
I want a set!
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Rick,
No matter what, the factory's dash harness is pretty weak. It's a finer gauge, like 18 or so, and there's no fuse. Any retrofit solution should go to a lower gauge wire with better power handling capability and a fuse for safety.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
While we're at it I'm hoping the bulb socket is capable of the increased draw.
I am interested in the results please keep us up to date.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
me four. i'll deal with the wire size, regardless.
Driving member
Yep,
I would love to be in if it works.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Count me in too.
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
RickM,
The instrument illumination bulb Black/Blue wiring is 0.5 mm^2, or slightly smaller than 20 ga on the AWG chart ... as shown below: My suggestion for bench testing is to use a variable 0 - 20 Volt power supply, monitored by a good digital multimeter, and set the variable supply to the same as your system Voltage -- measured above 2000 rpm with the headlights on ... which tends to run higher [14.5 - 15.0 Volt range] than most earlier cars! You could build a variable power supply with parts from Radio Shack ... a 24 Volt transformer, bridge rectifier, LM317T regulator chip, and a handfull of other parts should fill the bill! For a light meter ... I would suggest a Gossen Ultra-Pro with Fiber Optic probe. The bulb sockets won't be a problem, as you are only going from 142 mA at a nominal 14.0 Volts ... to 214 mA. My suggestion for wire size would be 16 ga. There really isn't a fire hazard here with the additional load, but an upgrade should be over-engineered to give the best illumination and reliability. It wouldn't hurt to incorporate a 2.5 or 3.5 Amp circuit breaker into the new wiring loom. One step in the upgrade should be to clean all of the bulb socket's body with automotive white polshing compound ... to get rid of any oxidation or corrosion, and give the best possible grounding, which does depend on the friction fit in each instrument! You can clean the receptacle for the bulb holders in each instrument by positioning the gauge face up, and apply polishing compound with a Q-tip, scrubbing the sides thoroughly ... followed by isopropyl alcohol on Q-tips as well.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I'm in...
'70 911S 1002938 '70 Ducati Mark 3D 350 |
Sweet, I've seen the light........ me too
Re: Guess what I have.....Hint: 3 Watt instrument bulbs.
I'm in for a set!
BTW, I'd be more concerned about the capabilities of the dash illumination rheostat than the wiring. The stock ~20 AWG wiring will support the additional load, but without knowing the details on the dimmer, I'd proceed with caution. A simple dimmer circuit could be installed to handle the extra load if need be. It could be driven off the stock rheostat.
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Where do I sigh up?
I'm in for a set.
1984 Targa |
Administrator
Build a better (or at least, brighter) mousetrap...
I'm in, too. You should sell a bulb-and-fuse-set combo.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I'm in for a set!
Before I opened the thread, my guess was burned-out dash light wiring and curled PC traces
![]() Do you guys really have trouble seeing your dash ?? I usually have my dimmer turned down 1/3 or even 1/2. |
I'd love to see my gauges at night. Count me in.
Tru6 Restoration & Design |
Definitely interested!
thanks dave
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
