Racer
preston_brown's Avatar
Woo Woo! Engine out. Fixing leaks, rear suspension, etc.
After struggling for quite some time with undoing the hard oil line at the rear of the engine, I finally got that undone over the weekend and I dropped the engine tonight. Now to fix (all?) the pesky oil leaks!
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 02-13-2007, 08:57 PM
Will program for food
ghnat's Avatar
Good job. It really is not that bad of a task - once everything is disconnected... Watch out for the dreaded while-you-are-in-there ...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 02-13-2007, 09:00 PM
haycait911's Avatar
Watch out for the dreaded while-you-are-in-there ... it seems once it's out and on a stand there's suddenly a LOT of things that you might as well do . my couple of oil leaks has turned into a shortblock and a couple of big pelican orders. hoping to have it running by april 1, maybe. Don.
Old 02-13-2007, 10:15 PM
zbph10's Avatar
Good jub, did my first engine pull about 6 months ago.
There seems to be no limit to the amount of money you can spend on these cars we love so dearly.
Oil leaks lead to tearing things aparts, cleaning leads to painting, painting leads to tearing more things apart, tearing things apart require need new orings or gaskets. Since the motor is out I better replace this bearing and that seal, may as well send the injectors off for cleaning since I tore the intake apart to clean and paint, new plug wires would be nice, better get a cap and rotor while I'm at it.
I could go on and on, funny thing is this is just the last two weeks of my full rebuild of my 3.2, it's been going on for months. Compared to the rebuild the above is childs play.
I'm not complaining because its a lot of fun, just funny, wifes not laughing though.
Good luck
Brian
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 02-14-2007, 12:51 AM
SP2 SP2 is offline
SP2's Avatar
Welcome to the club. I did mine in October and I am still having fun with it. But now as the weather improves I am moving quicker.
Congratulations!
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 02-14-2007, 01:09 AM
somebody actually bought and used that "body paint protector?"
Old 02-14-2007, 02:22 AM
Not Quite Banned
Thomas Owen's Avatar
Good job Preston. Take some pictures as you go along and then complete the post when you put the engine back in.
yelcab1 - I have one and have been using it for close to 25 years...
Thomas Owen
1972 911T
1972 911S
Old 02-14-2007, 03:28 AM
19 years and 17k posts...
azasadny's Avatar
Preston,
Congratulations! Once you've dropped and reinstalled the engine, you have much better knowledge of the things to look for and oil leak problems. Clean everything up and replace old hoses, clamps, etc... anything that you have a hard time getting to when the engine is installed.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-14-2007, 05:07 AM
Jascha's Avatar
Nice going, Preston... was this a solo job…?
My last engine swap was in an old Triumph TR4 -but I had Mothers’ help…!
Yes, my Mother was a farmer’s daughter (a feisty Russian partisan wearing Army boots)
Cheers,
Jascha
1995 993 ('Under my Care')
1989 911 ('Go Pitt')
1996 993 ('Go Navy')
1984 911 ('Go Pelican')
Old 02-14-2007, 06:02 AM
cfries's Avatar
Nice job Preston,
If you need a hand installing the engine, let me know. I am thinking about doing my first solo drop when needed and any experience is good to have
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 02-14-2007, 08:23 AM
MBruns for President
JeremyD's Avatar
Good for you Preston! now start cleaning that bad boy up!
Old 02-14-2007, 09:14 AM
good job preston. i would like to do that some time in the future. any advise. thanks.
Old 02-14-2007, 09:21 AM
GothingNC's Avatar
Preston,
Congratulations !
Nice to see another Tar-heel at work
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 02-14-2007, 01:17 PM
Racer
Yeah, I did it solo. I had a real b*tch of a time undoing the hard oil line at the back of the case, ended up having to grind a little notch in it and use an air chisel to get it loosened. There's another thread on here about that somewhere. I used the engine cradle for 3.2L engines that Pelican Parts sells, it definitely helped provide a stable platform when lowering.
From the looks of it, the major oil leak is from the temp sender, but I suppose there are probably more than one. I'll definitely take pictures as I disassemble and update the thread as it progresses.
-- Preston
Preston Brown
Old 02-14-2007, 01:31 PM
syncroid's Avatar
Good job on the first engine pull Preston. Make sure that you replace the thermostat oring too when you are replacing the oil pressure switch. 999 707 314 40 is the part # for that. Are you going to separate the trans. from the engine? You should if had not already planned to do so. Main shaft seals on the G-50 boxes go bad occasionally. Take a good look at the clutch and flywheel seal too.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 02-14-2007, 02:00 PM
cygtoad's Avatar
Sweet.   I wish I were there to have watched the operation. How many hours did it take?
_______________________
Unless you change your course, you are likely to end up where you are headed.
'87 Carrera, Black on Black
Old 02-14-2007, 02:33 PM
cygtoad's Avatar
...and be honest.
Old 02-14-2007, 02:34 PM
austin552's Avatar
Wow!! Solo drop, you got big'ens. Nows the time to sell it to me and get that 3.6.
1974 911s
Old 02-14-2007, 03:45 PM
buttjoint's Avatar
Nice job On the oil line I used a 14 inch pipe wrench very carefully. It came loose no problem. Oh well, next time Jim
Old 02-14-2007, 03:58 PM
mppickett's Avatar
Nice work, Preston! I like the look of your tool chests. I'd bet you don't need a LOT of help but if you do just give a yell. Several of us are close and don't mind giving a hand if you need it.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 02-14-2007, 04:22 PM
