Add a pair of twin plugged advantec 4 vavle heads!!!
It lives. I fired it up last night. I will try to post more pics and videos.
I don't think you could cool the heads with the 4 valve design. Wasn't that the short of these heads in their initial introduction and the reason Porsche went to water cooled heads. Heresy!
I don't think valve area/flow is going to be the limiting factor here......HEAT as Beep Beep pointed out will limit this engine. Though it should be a NICE limit. We wait those charts.....please include AFR's and head temps on the graphs.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
I think 921.32999 hp.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
This must wait for a few weeks. My wife just kicked out a little boy. It does sound amazing though. The turbos at idle push lots of air.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Engine is in but the turbos are leaking I am using a -4 and a restrictor for the feed line and a -6 for the return. The engine reves up like a motorcycle engine. |
Me like track days
Go Speed Racer, Go.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Congrats on the baby, all the best to you.
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
Awesome looking machine. Sorry to hear about the leaks. IMO, -4 is too big a feed. I'd use -3 personally and no restrictor, since these motors have a low oil pressure at idle. Anything under 2.0bar and you don't require a restrictor. That's how I run my single GT35R and I have no issues with oiling etc.
How do I post sound clips or videos here????????????????
I really sounds unique. |
Here is a pic of my factory 1987 turbo look cab. Protomotive did the stage 3 set up with a t66 turbo. It hits very hard at full boost. I am going to go with a gt42r or a gt40r. They sound totally different |
![]() wrong car how do i remove this? Slantnose in the background. Last edited by speeed racr; 05-02-2007 at 06:02 PM.. |
Very nice slantnose Cab
Yeh the Protomotive stuff rocks! Doesn't a T66 flow more than (or equal to) a GT40R? A GT42R would make a tonne of power, but might be a bit laggy on a 3.3L I would have thought?
any ideas??????
Banned
The outlet lines needs to be bigger,eg./-8, I might be wrong, but it seems that the lines at the scavenge pump are hooked incorrectly, if this is not the case, you might try plumbing a scavenge line to the engine oil sump, or you can use a larger scavenge pump, PM me if you need one, I have a nice Petersen double stage pump, that will suck dry those turbos., Candy.
A fellow Pelacanite
A lot of the single turbo guys like getting rid of the stock drain pump. They lose some weight by binning that pump and draining their turbo into the sump plate on early engines or the drain plug on later engines. Another option can be draining into the timing chain covers.
Not sure what you can do with no pump or pumps as you are tt though.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Speedracer- did you put the little spring loaded check valve back in the top of your after market turbos? On the stock twins, they have a little spring and ball check valve on the inlet of the turbo. Is the oil entering the housings on shut down?
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
no check valve and the oil is entering the housing during shut down. I have a -4 with a restrictor If you look at the pic you can see that i have a oil reservoir drain under the turbo, then to the -6 return line. Also look at the pic of the oil return pump on the back of the engine i may try to clock it differently. What do you think?
A fellow Pelacanite
I just looked at your pic. You went over the tranny with a drain. Can you try going under it instead ? Is it possible you have an air lock ?
