Maltese Falcon's Avatar
Garrett tel# 310-517-1981 Fax# 310-534-5941
sorry no email contact. Call and ask for an engineer in turbo or turbo kit development.
Marty
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 05-28-2007, 11:11 PM
WydRyd's Avatar
Originally posted by speeed racr
The turbos are brand new. They only have about 15-20 min of run time on them. I am running oil through the water passage.
From my personal experience with the Garrett BB's, you don't need to run oil through the water passages. That's how I run mine. Oil cooled only and the water ports are left open. I run my car pretty hard and it's my daily driver and I have no oiling issues whatsoever. -4AN oil feed, NON-restricted.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-29-2007, 01:07 AM
Banned
I agree, no water needed, been using these since they came out, on air cooled engines, no problem at all, you can use oil to cool them out, cheers, Candy.
Old 05-29-2007, 06:03 AM
Here is the new set upand they still leak.
Old 06-01-2007, 12:37 PM
Marty
I called them they were no help. thanks anyway.
Old 06-01-2007, 12:46 PM
Banned
You need to clock the center housing oil outlet 90 degrees from horizontal, also the hole in the valve cover must align with the oil return tube, also it seems to me that the turbos are positioned to low. You may try to scavenge the oil thru the main sump or use a better (bigger) scavenge pump. Candy.
Old 06-01-2007, 12:51 PM
