1989 930 turbo what to replace?
![]() so what do you reckon boys piston rings leaking oil right? ![]() thats oil leaking residue through the rings right? ![]() think some steelmate will do the trick? ![]() i need a valve removing tool so replace rings headgasket? a valve because of mark on piston looks like its been done already? and gaskets? |
Pretty hard to diagnose from pics. Obviously needs some work.
Some prior testing would have been useful - leakdown/compression etc. Running symptoms. Probably pay to pull the pistons and measure rings/bore etc. Get heads inspected to see if need machining the faces. Check valve guide wear while you are in there, and valve stems/faces. As for the crank end?? Is it cracked? Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I've gone native
I'd send it all off to a good machine shop, valve job and basic rebuild/balancing/blueprint.
'07 997.1tt Blk/blk 600hp, bad to the bone |
Air Medal or two
While your heads are off double plug them. Gives you more options later
A Vale spring compressor to remove your vales is not that expensive...However after that you are at a dead end unless you purchase a hard seat grinder, valve facer, pilots and what all. These are all needed for a proper job. "IF" you have not ever done valve work B4 it will be a challenge . Figure 1000 to 2000 in used tools if you are lucky and patient enough to find them ! I am VERY fussy when it comes to head work and feel no one will do it as well as me, or take the time to get it all Purrfect. If you elect to have a out side Vendor do it, Please use one that specializes in Porsche. I am NOT being a downer here.If you have skills you can learn the ropes..but start on a junk head to learn what to look for. Removing and pressing the guides are a trick in them selves compared to a traditional type engine. May the force be with you.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
