Anyone Know Who Makes This Manual Boost Controller?
I want to replace it with the same one. I just recently got the car and today I took a look at it. It states on the top to pull to adjust and when I pull it up and try to turn it, it just turns freely, wont stop no matter which way I turn it.
16 VW Touareg 05 Porsche Cayenne S 87 Porsche 930 84 VW Rabbit GTI |
Hard to tell from that pic alone. There are two types 1- is ball and spring which uses the adjusted spring pressure to control the pressure to waste gate and are fast acting at set pressure. 2- is more of a controlled leak. Adjustment opens a vent to increase boost pressure and if vent is closed more it lowers boost. Not as fast or controled to waste gate.
I know that didn't answer your question but there are many different places to buy these. If I wasn't on my phone I would google for a link for you. B |
Looks like the one from Turbonetics.
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
89 930.
Turbonetics... got 1 same as that one
Thanks guys... I'll need to take a look at mine again. That one looks to have 3 ports where I thought mine has 2.
Slantnose from HELL
That is a Turbonetics 2 port, you can purchase it at Jeg's
Turbonetics 10402-25 Turbonetics Variable Boost Control Kits
It changes from time to time..... |
Do you have a death wish ? I've got on I'll send you!! Seriously good way to blow up a perfectly good engine
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Slantnose from HELL
Nothing wrong with them.... it is just a adjustable wastegate controller. It can't blow up anything! Now the idiot that doesn't know how they work and or not know when to stop turning the knob on the other hand CAN blow things up! So technically it's the end user that's to blame. It is because these rocket scientists who end up blowing up their motors because they kept turning the knob past the fuel and ignition timing capabilities. Instead of blaming "themselves" They point the finger at a simple device and nick name it ? "Dial-A-Death" . For example, If these genius's would understand that their fuel and timing capabilities are only good to let's say 1 bar, and they have a .7 bar spring in their waste gate, then one could purchase a manual boost controller and add adjustability and be able to fine tune overall boost limit to 1 bar. But since it can boost more the fuel and timing doesn't support it the end user is the Pulitzer prize winner that pushed it beyond the systems ability. Not calling anyone specifically out, just a little venting.
Open the case and check the connection with the handle. That never ending twisting happened to me before and it was that the T handle became disengaged from the actual valve. Easy fix.
Andial also has a very similar control. I bought an 84 Carrera that had been converted some time ago by Andial and it had a "dial of death". I called Andial in CA and they had one on the shelf. I don't think they had sold one in a while. It's basically a simple air pressure regulator. It was about $58 if I recall. not nearly as expensive and I would have thought. If needed PM me I may still have the part number. I have since gone megasquirt with boost control and efi. It's under the knife, but now in the car thanks to a good friend.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
beancounter
No death wish here...Seriously. You know that I built my engine with my very own hands and I have an MBC. It is inside the engine compartment to avoid temptation. When I upgraded my exhaust system, my boost level dropped slightly (which I attribute to a more efficient wastegate circuit). I added an MBC at that time to bring the boost level back up. I always run it at <1 bar. Its pretty easy for me not to twist that knob all the way to max since I remember very well how much I spent building the engine.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Well it turned out to be a $15 Norgren regulator. I'm going to just order a new one and keep it right under 1 bar. My paper work that came with the car states it has a 1.1 bar waste gate spring.
My vote is for "dial a death" At least you know where death is....
Looking Good..
Slantnose from HELL
"THE" and I mean "THE" Best MBC ever made on the planet. I want one! I talked to Kevin at Gunnar looking for a NOS valve but it is no longer available from Porsche. Haven't Been able to find a nice example and they are getting harder to find even the beat up ones.
