Banned
Heh, I'm really glad ^that^ resonated with at least someone!
Catchcan FTW! Leave the resin in yer bong!!! What's the status update on your car's resurrection? Jeff, really nice work you're doing there... spring's coming - we'll have to meet up for a Northeastern'ers drive jah? There's efreakinnuff of us around here certainly!!! |
Banned
You are most welcome for the lesson, Paul! |
Shocks went in last night without too much drama. Next up is painting the tins.
Paul - definitely need to meet up once I have it running. So, can someone point me to some links to the process for replacing the airbox with the K&N filter? I know there are other hoses plugged in and want to figure this out before I put my motor in. I've seen some threads about it, but cant find any now! Any advice out there?
1988 930 Venetian Blue |
Banned
Jeff, I did it this way - - crank case/oil tank vent "Y" hose attached to catch can - vent hose from fuel vapor, charcoal canister in right rear wheel well attached to catch can - catch can vented to atmosphere via a long hose running from the top of the can and out of the engine bay - hose follows the same path as the a/c refrigerant hoses on the right side. I then secured the end of the hose to the right rear swaybar mount with zip ties. The hose is pointed at the ground (tip just below the swaybar drop link - not THAT tip, Paul) and I cut it at a rearward facing angle in the hope of preventing air from easily rushing into it while driving. I did this because I did not want the vapor from the catch can vented into the engine bay. - WUR vented to atmosphere - although I like how some people have vented it to the top of the air filter, so I might do that at some point. Last edited by Ronnie's.930; 03-17-2015 at 08:37 AM.. |
Banned
Ronnie, the pedantic former teacher / current PED:
"friends do not let friends vent SANS CATCH CAN" how's that, yafukkindooooooooosh!? now, quit wasting mah fukkin time on the likes of yer uberdooshism - I'm a busy man afterall!: ![]() |
Banned
^^^ Much morer betterer wording, Paul, and I would offer you some free candy as a reward, butt I can't errrrr ummmmm, spare any at this time!
PorscheMoparLiterbike
Orient the WUR vent so rain/water doesn't get in....could screw up the WUR over time...ask me how I know
88 930 BnB Kinesis tial 1bar k27/29, Turbokraft IC+blocks+rokr loks+ ported intake,edelweiss cams, KEP/Sachs, Verden Tool 38mm PP heads, ARP bolts/studs, twin plug for future |
Ummm, isn't that how a WUR is supposed to work? The Leask special?
Haaa...crazy thing is it ran pretty good even in this condition. Larry from flow tech got me a new one ....all better now.
Shocks mounted! Suspension is done!
New engine seal installed. New oil cooler seal installed. ![]() ![]() ![]()
Anyone know where this plugs in? I assume it is a brake pad wear indicator, but I can't see where to plug it in and can't find any pics showing where...
Do I need it? Both sides were unplugged already. ![]()
Banned
it should clip into the pad, if the pad has the slot to accept it (like Ronknees)
Engine tins painted!
Installed my new AC condenser (Griffiths system) and repaired and repainted the condenser guard and mounted that up.
Got my fuel lines from Len today. Ordered a Hooligan muffler from Rarlyl8!! Cant wait to get it. ![]()
Banned
Good looking paintwork thar, Jeff. I also spy what looks to be a new, smaller than OEM out diameter, r134a compatible hose - nice (something I still want to do to my a/c system at some point - all new hoses).
Man, Griff is a great guy, and a hilarious poster in the 911 forums - have had some good times cutting up with him in the various, crazy a/c threads over there. ![]() |
I'm gonna have cold air this summer! Turns out, Charlie's shop is like 20 minutes from me, so I went there to pick it up and chatted with him for a while. Great guy!
Got the three rear fuel lines installed last night. Didn't realize I need bushings for the tunnel lines, so I'm waiting until I get the bushings to do the tunnel and front lines.
Looking good. Keep the updates coming.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() ![]() ![]() |
Started reassembling the motor. Alternator, fan, shroud, engine tins, electrical, etc.
Still lots to put back on. It's funny, because I took hundreds of pics pulling it apart, but yet I still keep finding things where I say "where does this go?" ![]() ![]() ![]()
Jeff, you're killing it this winter! Super motivating. I just have to reinstall my headers, redo a cv boot, and adjust my valves and for some reason I walk out to the garage, flip the light on, look at the car for a minute and go back in the house. I've helped out on a few other cars lately but can't look at mine right now.
Thanks for the boost!
Ken 1986 930 2016 R1200RS |
