adding weight to piston?
I've got 5 new P&Cs with pistons matched weight group and pin/piston all within 1 gm. I have a 6th new P/C which is 9gm lighter than the rest. Is there any way to add 9gm weight to the one piston/(pin) or do I have to find a way to take 9gm off the other 5.
Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) Last edited by Alan L; 02-10-2016 at 03:40 PM.. |
Or, can I reduce 1 piston/pin by 9gm and place them at the fan end (1&4).
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Air Medal or two
Find the lightest and match it .
Thats what most do afaik , and what I always do. It will not be hard to get rid of 9 gms. I always shoot for zero, I sleep better.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I got 5 'heavy' ones and one light one. The light one is the one I just received - at the bottom end of the lightest weight group. So do i have to lighten the other 5, or can I add weight to the light one?
Alan
Reread post # 3.
Air Medal or two
Go lighter is what would do in a heartbeat.
I made a mistake ( Imagine that LOL) -One time and took off weight on the lightest one. My engine thankfully. I had to rematch all of them to a EXTREAM light number. It came out SUPER light . I shaved from every known spot to man. This engine has over 30K miles of Spirited driving on it and still purrs.
regards Alan
Do it nice or do it twice! |
OK, guess I better get my grinding gear out. Curse. Yes a rebuild is a bit cumbersome to rid an oil consumption issue - but I had just fitted a used set of P/Cs to replace my worn out set - beyond wear limit, but still working OK. But the rings on the 2nd set don't appear to have bedded in. I could have just gone thru the process again, hoping for better results with a new set of rings. But I had a part set (5) of new P/Cs - so decided to 'do it nice or do it twice'.
Regards Alan
Air Medal or two
With a 3 beam scale you will have it done inside 2 hours. EZ
Alan
Air Medal or two
There is really no magic involved .
Just make sure you leave NO burrs! I have not ever had a piston comeback because I took too much weight off. Like I said, I screwed my own up one time really bad. It came out with pistons that were lighter than RSR stuff. It would SCREAM! I talk to the guy that bought it from time to time. No problems . We shoot for pirrrfection.......that makes at least hit the target.
What weight difference actually matters? There must be a point where it doesn't make any difference as things such as friction etc override any minimal weight differences?
Schleprock
Wait until you start removing material from the piston. It's slow going when removing 9g. You keep milling material away, weigh it, remove some more, weight it again, still not even close, remove more, STILL a long way to go............ etc.
Kevin L '86 Carrera "Larry" |
Air Medal or two
You can take some off the pin too.
I planned to start on the pins - figured that was where the bulk surplus weight was (and I have a lathe which may/or may not help). Was going to see how far I could get with the pins, then finish on pistons.
Alan
Air Medal or two
You will do just fine.
Waynes book says 'the machinist will remove weight from the pin' as per pic. How would they do this? I have spent about an hour with dremel and stone, and have not removed a gm. I still got 45gm to go. It is too hard for my lathe tools.
Regards Alan
Banned
Alan, here is how Jim did his by hand - looks pretty sweet (post #4 for pistons/pins) -
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/800923-connecting-rods-balanced.html |
Hi there Ron. That is mainly about balancing the rods. Jim had another post - which I read, on doing the pistons and pins. He said he used a die grinder bit on the pins. I'm not sure exactly what sort of bit he used - but I have tried a metal fluted bit I used on my intake manifold and I tried a grinding stone. Both suggest i will be here til Xmas before I can reassemble. There must be a more effective way to remove 45 gm of tough metal. Ideally I would like to use the lathe - since I got one.
Thanks Alan
