DGI DGI is offline
DGI's Avatar
DGI's 2003 BCR #90
Checked off a bucket list item today!
Bought a 2003 Boxer Cup Replika from its owner of 17 years and brought it home.
Bike has ~37K miles and looks like its been well loved but well ridden also. Its got some road scars but will now be slowly gone through.
I've had a couple of bikes in the past but in 2010 I bought a 1978 CB750 and proceeded to "Cafe" it. Well its been 4 years since that bike's been on the road. Today I drove it down to a shop near Leesburg, VA called MotoRelic and on the way back I swung by to look at the BCR. I figured It'll be my reliable bike for when the Honda is under the knife.
My main concern was that my height would be an issue. At 6'6", most bikes just dont fit.
I was pleasantly surprised that I felt comfortable on the bike.
The seller was kind enough to give me a set of hard BMW Panniers, a spare Corbin seat, the original BCR box and paperwork (Missing the model), and a bunch of tools and parts to go with the bike. H
His father has a 2004 R1100S also and sold me a Laser cat back while I was there.
Overall, I think I got a smoking deal but the bike needs some attention. There are scratches and road grime throughout, some broken trim and missing decals. New tires are needed and im going to go through the 40K service checklist to ensure everything looks in order.
Looking forward to many years on this beauty!
-Dimitri
Old 09-10-2024, 01:26 PM
908/930's Avatar
Congratulations on your purchase. As you probably already know, there is lots of good info if you search through this forum.
Old 09-10-2024, 02:05 PM
Jersey Boy In Texas
njsax's Avatar
Cool! I like the Mamola livery.
John Filak
Dallas, Texas
Old 09-11-2024, 12:10 PM
DGI DGI is offline
DGI's Avatar
A member of this board sold me a full Staintune exhaust setup that looks brand new as well as a set of Ohlins suspension. He was also kind enough to hold my hand trough the purchase of this bike, answering questions and sharing in my excitement.
So parts are incoming, and bike hasnt hit the pavement yet 🤪
Bike should be registered tomorrow!
BTW: Called up Hagerty to add the BCR to my collector’s policy and it was only $71 a year! Looks like I may be getting into motorcycles a little more! Wayyy cheaper to insure than car AND they take up alot less space lol
Old 09-12-2024, 01:47 AM
‘03 BCR purchase
Congratulations on the ‘03 BCR purchase! I have an ‘04 BCR (#78). I did have #73 as well as an ‘04 S. I’ve got quite a few spare parts and a lot of maintenance time on these bikes. I’d be happy to help you sort it out.
Should you want to move the bars to the top of the top clamp, I have a spare set of top bars. Your low bars can be moved to the top but an anti rotation strap is needed. The made-for-the-top bars are a bit cleaner looking as they have no “ear” (to which the anti rotation strap connects).
Old 09-12-2024, 06:06 AM
Been Nowhere Done Nothing
Swamper's Avatar
I've got mine insured that way also. But they won't insure newer bikes.
05 R1100S BCR, 04 R1150R
16 S1000XR, 24 S1000RR,
21 Ducati 950S
Old 09-12-2024, 07:28 AM
DGI DGI is offline
DGI's Avatar
Thanks for the offer bud! I may need some help going through this beauty. Will stay in touch!
I have no interest in newer bikes. I dont commute with a bike, just like buying and selling stuff and getting to experience different things. The BCR is here to stay though
Old 09-12-2024, 09:38 AM
DGI DGI is offline
DGI's Avatar
Member @MPG Steve Posted this in a different thread and im reposting it here for reference down the road
"I’ve had two ‘04 BCRs and an ‘04 R1100S. To help keep track of which BCR I’m referencing I’ll refer to the last two digits of the VIN # as they were only 41-VIN #s apart. VIN # 55 I bought used in FL in 2011 with 9,000 miles. #96 I bought in WI in 2016 with 2,500 miles. I believe I was third owner on both. I was able to get factory AIR sheets (from Holt BMW Athens OH) which give some info on build dates, warranty and appointments but no # of 300. Both bikes came through the same Chicago dealer in July of ‘04.
The ‘04 R1100S I’ll refer to it as the “S”. I bought S used (3rd owner) with 10,000 miles. It was the comfort version and had a Ztechnik pipe. It had the long torque arm and narrow rear wheel and no steering damper.
I have ridden this fleet of three to a total of 200,000 miles. I’ve had no major mechanical issues. The S’s forward FD seal began to weep at around 75,000 miles. At 83,000 miles on the S, 62,000 miles on # 55 and currently, 20,000 on # 96 the pivot bearings were/are original. I attribute this to regular retorquing. However, S being my first of this type did have pb’s that were loosening. Finding this play, doing the side-to-side check, led me to do my first retorque. With loose pb’s the bike turns faster as the rear wheel begins to castor. After tightening the pb’s, I was caught out at the end of my longish driveway when the bike didn’t turn as fast. I almost took out my mailbox.
All had ABS with servo-assisted (power), linked brakes. Nine brake bleeders. Both 55 and 96 had stock pipes, steering dampers, wide rear wheel, belly pan, CF valve cover protectors and short torque arms. 55 was the comfort version with clip ons above the top clamp and a convex (tall) windscreen and 96 was the standard configuration of clip ons below the top clamp and a concave windscreen. The S had been converted to the comfort configuration as it had the low clip ons moved to the top which requires an addition anti-rotation strap.
One of the BCRs did have its “# of 300” plate, the other didn’t. I spent much time querying BMW Motorrad and BMWNA attempting to find out what number of 300 96 was. Even though my two BCR’s were only 41-VIN numbers apart, BMW had no idea whatsoever how to determine the number.
I called, e-mailed and finally, early this year using BMW’s newest form of customer service, I “chatted” with Motorrad and NA. When I received the boilerplate “please rate our service” prompt I let them know that I felt the Corporation was lacking. The next day I got a call from Customer Service, for which I commend them but they still had no clue as to what # of 300 96 is.
Shortly thereafter I tried one more trick. I called one of the oldest BMW motorcycle dealers in the country and asked for the oldest parts person. I will call him “Bob” as much personal effort was put in on his part and I don’t want people calling him for help in this matter without my contacting him first to see if he wants to spend the hours doing the research that is required to determine the build number. I rewarded Bob for his help and would expect the same from anyone who he helps in this matter.
Bob figured out that he could see the MSRP of each VIN number of this S assembly line progression. All these builds were identified as S’s, no BCR distinction. The price of a BCR was around $3,000 more than an S. By searching the MSRP’s between 55 and 96 he was able to see four more identically high-price S’s. I feel confident his method positively gives 96 its correct build-number.
I found an Ohio data plate manufacturer who could reproduce the plaque.
‘04 on had twin spark ignition systems. The center coil is a coil in cap design. The original PN coil fails at about 20,000 miles. I went through two sets, one under warranty and one set out of pocket. Finally BMW fixed the problem around ‘08-‘09. I have moved these superseded coils to to 55 and then 96. The original coils I put on the bike I sold; I made it clear to the new owners that the coils would fail. I kept in touch with the those who bought my S and 55. Those old design coils both failed around 20K. A low mileage S/BCR will most likely have the old coil PN. Plan on a $300 upgrade.
Having no center stand, maintenance can be troublesome on the BCR. The BCR tool kit has no lug wrench! My guess is with no center stand the end user wasn’t expected remove the rear wheel. This and no QDs makes me think BMW was wanting to cut weight which is a bit ludicrous considering the heavy weight of the BCR.
BMW made (and may still be available) spools that attach at the belly pan rear-mounts (center stand mount on S’s). These spools receive Pit Bull rear stands. With a pit stand and a 2” PVC pipe placed vertically, capturing the Telelever’s lower knuckle, a small jack will lift the front wheel. Once “up”, the PVC needs to be clamped to the belly pan’s vertical inlet strut as the three-point lift is a bit wobbly. This configuration allows both wheels to be removed at the same time.
Wheel chocks work but limit the front or rear wheel maintenance options. An A frame or overhead hoist works great; loop-choking the top clamp (avoiding wiring and plumbing) is a very secure method. The hoist also is very helpful when removing the fuel tank especially when it’s full.
The tank is an irregularly-shaped aluminum saddle. Be careful not to ground the battery terminals which are” a few millimeters below the tank’s rear section. Having metal QDs is very helpful in this operation. It eliminates having to pinch the fuel supply and return lines (which in part of their lengths have internal hard lines that can be crushed by a pinch in the wrong place) but also provides a drain port for the fuel tank. QD’s are also shutoff valves so draining the tank requires another QD with a drain hose fitted. It has come in handy on the road when a fellow rider runs out of gas. The plastic QD works fine in this drain-only condition.
The tank-capacity is not great. Coupled with 40-ish mpg at speeds over 80 mph, 250-at speed-miles is the furthest extent of its range. I carry four one-liter fuel bottles in bicycle water bottle holders mounted on my saddlebags.
[Note: BCRs didn’t have QDs which is good because the plastic QDs BMW used in that era all fail. Someone might have added QDs to a BCR. Hopefully they are the upgraded steel variety.]
Accessing the battery takes about 40-minutes of disassembly/assembly if you are well versed in its R&R. Sometimes lifting the tank is required. If not ridden weekly a battery tender is a must. BMW makes a jump lug-kit which is cheap and easy to install. It places a positive and negative terminal in an easily accessed area on the starter cover and the left cylinder. Charging alligator clips or jumper cables work great here.
To access the battery the left and right main fairing must be removed. When removing the fairing-halves the first time be careful as the two lowest fasteners (one each side) are nearly invisibly-located. They are located behind the BMW roundel. They are accessed from the inside. A ball-end Allen wrench is useful here. I’ve done work on many S/BCRs. Many times I’ve found this mount broken. If broken on the left side and the bike placed on the side stand (always necessary on BCRs), the heat from the left head pipe will blister the blue checkerboard graphic on that side. There are six-fasteners per side (all the same Allen-size).
2003 BCR #90 https://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/1166870-dgis-2003-bcr-90-a.html
Old 09-12-2024, 11:43 AM
DGI DGI is offline
DGI's Avatar
Part 2 from @MPG Steve
The least durable and therefore shortest-lived part is the seat. Shorter riders seem to pinch the sides of the seat when putting feet down. Very aggressive side to side movement like that during track days, puts a lot of stress on the seat, breaking down the vinyl along its sides. It cracks. Additionally the seat is very uncomfortable. A Sergeant and Corbin seat were no better comfort-wise. They do seem to be of better-quality vinyl as do Polish and French aftermarket seat covers. When recovering the seat, do not attempt to remove the old cover as it is glued to the foam cushion and will crater the foam if removed.
I found the seat to be very uncomfortable during 100-mile days. I fabricated an adjustable air seat from a Therarest pillow, Camelback hose assembly and a blood pressure bulb. Mounted on top of the seat in a Gortex sleeve it is possible to quickly inflate, deflate or adjust the air pressure from the left handle bar. 700-mile days became possible.
10,000 miles seems to be the limit of the stock seat before the cracks begin.
A turn signal paddle wore out after 130,000 miles (I moved the hot grips from S to 55 and then to 96 so the same switch got lots of use). I averaged 13,000 miles per year from ‘06 to ‘16. The majority of the miles were a daily commute of 30-miles round trip in all kinds of weather, every day. I estimate at least 70,000 actuations of the turn signal paddles over ten years of commuting so one switch failure seems to confirm the switches to be reliable. Further, the switches are rebuildable (from donor clusters; no kit is made), so a new cluster is not required.
The alternator on the ABS, power brake versions have the highest output of the series. During cold weather I am able to run heated visor, heated jacket, heated pants, heated gloves, heated socks and heated seat with no issues. 30-miles per day (20 miles of that at interstate-speeds) kept the battery charged. Make sure to use at minimum a 19 amp hour battery. Unlimited-life alternator drive belts are available. I never had to change one.
On a weekly-ridden bike the battery has about a five- to six-year life. I was able to get almost 60,000 miles from brake pads and I’m a heavy braker. Being linked, all three brakes get a workout even if only using the front brake. Tires averaged about 6,000 miles on the rear and 10,000 miles on the front. Again with constant riding, the fuel lines, the brake fluid and clutch fluid seems to last forever.
If the bike is not ridden much and especially if it goes through large temperature and humidity swings, the fluids are going to have water condensation-problems. If the charcoal canister has been removed and the fuel tank is allowed to vent to atmosphere, tank condensation is accelerated. The fuel pump and filter are in the tank and the R&R is quite time consuming and/or expensive. This leads to it being neglected. Long dormant spells (no riding) with fuel in the tank leads to shellacking the pump and softening the in-tank hoses. This burns out pump motors and ruptures hoses.
The ABS pump module’s orifices can become clogged with flexible hose material and hygroscopic corrosion if the bike is not ridden.
All this adds up to some big bucks when having to replace brake and clutch lines, ABS module and fuel pump. Add to this two center coils, QDs, tires and battery and the rehab price is easily 4-5,000 dollars if the work is performed by a shop and not you.
With ABS the bike is a great all weather commuter. Conversely with permanent, all-time ABS, the rear wheel cannot be skidded, limiting track-performance. Two gear, clutch-dumping down shifts will get a short duration skid. The BCR weighs about 500-pounds which is very heavy for a track bike. Being a big twin makes for excellent torque which helps coming out of corners but still it will be waxed by a competently-ridden 600 cc Japenese, any brand sport bike. Supposedly the aftermarket pipes; Laser, Ztechnik etc. add a few horsepower. I think this is a negligible improvement but the dropping of nearly 20-pounds is an improvement.
With the aforementioned air seat the BCR is a great cross county bike as it accepts standard, factory bags (3-lid sizes) and aftermarket top boxes. The stock tank bag is small and goofy-looking. Many aftermarket tank bags work. One problem is that a large tank bag will depress the horn button when maneuvering lock to lock. A foam earplug under the horn paddle creates enough resistance to usually eliminate this. The paddle is still thumb-able for intentional honking.
The side stand is a bit short and having a foot pad in your pocket or tank bag is useful. Conversely a fully loaded bike; tank bag, top box, saddle bags and fuel bottles compresses the suspension enough that tipping over to the right on the side stand is a possibility.
The second weakest part is the suspension. While I had both BCRs at the same time, I upgraded 96 with a Wilbers suspension. 96 had only 3,000 miles on its stock suspension and therefore was “new”. The difference was remarkable. In fact it was so much better I was afraid I would forget which bike I was riding and attempt maneuvers that would catch me out on 55 so I added the same Wilber’s to it.
A Throttlemeister throttle lock is helpful as is an aftermarket throttle paddle for touring. The return spring isn’t as heavy as on large four cylinder carburetored bikes but still requires some effort to overcome.
The carbon fiber belly pan, which weighs just 20-ounces, is easily dinged. A front fender extender is a must. Last time I checked a belly pan was still available from BMW Germany for $3,200 so it pays to take care of it. When removing it find a way to suspend the bike so the side stand can be moved as needed to slip the pan down and left. It’s easier if the bike is lifted at least six inches off it front wheel (get a hoist).
There is no rear fender so the under seat pan, mufflers and rear shock get impacted and dirty. A hugger fender is very useful.
The tail light and brake light are typical of early 21st century design-they suck. Further with an aftermarket pipe, more heat is released in close proximity to the conventional incandescent dual-filament bulb. Vibration plus extra heat on hot days will abrade the lead contact buttons on the bulb enough to create an open. If either tail or brake light fails an instrument red light illuminates. If it’s the tail light that has failed, microprocessor logic takes over and sends continuous low power to the brake light filament creating a tail light while allowing more power with brake actuation. It will drive you nuts trying to figure out the warning light’s indication because the tail and brake light still”work”. The metal tangs in the socket can be bent to make contact but it’s a good idea to replace the bulb.
Hyperlites are made to add brake lights in the rear turn signal pods. Various light bars are available too. A brake flasher is a very good idea. I fabricate LED light systems and have made tail light, brake light and turn signal lights for both my air bag vest and helmet. I recommend a helmet light assembly for all weather, night commuting.
Motolights makes very durable front caliper driving lights (vertical separation from the head light to additional light is a must; additional lights in the horizontal plane-adjacent to the head light makes the bike appear to be a car and further away from the viewer than actual distance, increasing the likelihood of a collision)."
Old 09-12-2024, 11:44 AM
DGI DGI is offline
DGI's Avatar
Took my first ride today! 20 min around some side streets in my neighborhood.
Bike performed well. I did the best I could given I havent been on two wheels in over 4 years.
It was a bit soft and wallowy but that could be how the bike is currently setup.
Throttle at low speeds is stable. Bike doesnt like to be bogged down.
Noticed the bike didnt take left turns as easily as right turns. Was told to make sure steering damper isnt binding… need to dig deeper
Teaser shot from today’s delivery
Old 09-13-2024, 01:09 PM
bobr11s
Glad to hear yu are enjoying it . last weekend planned a 600km day trip on a public holiday next week . told my riding buddies so they can see who is free to ride with .
Was going to take another bike , but after reading your report i got enthusiastic and want to use my big yellow r11s . Wife loves the back seat , on straight bits at steady speed , she falls asleep on the back and relaxes against me . As soon as i speed up or slow down she is wide awake again .
Ride it or it rusts .
Old 09-16-2024, 12:46 AM
[QUOTE=DGI;12320590]Took my first ride today! 20 min around some side streets in my neighborhood.
DGI,
I have a 2004 R1100s Prep. I have a little more mileage at 60,000. I have Wilber shocks front and rear. I have always loved how planted the bike is.
That being said, last year I was having a problem with my bike not wanting to turn left like it always seemed too. My first thought was something serious must be worn or loose. I put it away for a few days and spent time riding my other bike. I started to think about tires and looked to see how many miles were on them. They had about 6,000 miles. I looked at them and they were wearing unevenly on the front. I looked at my other bike and it was doing a similar thing. I decided to put new tires on both bikes.
When I rode the BMW with the new tires it was beautiful again. My point is don't rule out the tires. They affected my bike more than I have ever felt in all the years I have been riding.
Old 09-17-2024, 12:31 PM
DGI DGI is offline
DGI's Avatar
Good tip, thanks!!!
The tires need to be replaced so thats also on the list.
Im leaning towards Michelin Road GTs.
Old 09-18-2024, 06:00 AM
Swamper's Avatar
Get sport tires for it, makes a big difference.
I found the Continental Sport Attack 4's to be really good on the S bikes.
21 Ducati 950S
Old 09-18-2024, 07:01 AM
Send a message via AIM to tomvv11
These bikes are not so heavy as to really need the GTs.
PR 4 or 5 or Road 6 in regular would do you just fine.
Old 09-20-2024, 01:37 PM
Registered Agitator
sgoodwin's Avatar
I also prefer sport tires, been running Bridgestone S22's & find they're plenty sticky for road work. Tried a couple sport touring tires & only got about 500 miles more with far less confidence on fun roads.
Old 09-21-2024, 06:31 PM
Banned
Old 09-24-2024, 05:24 PM
A lot of great info here. Thanks for posting.
I bought an 04 BCR in April. Love it! Factory suspension and exhaust. Good enough for my (spirited) commuting.
ABS model but has been disabled. I will be looking for ABS advice this winter… if I stop riding long enough.
BIG change from the 03 650 Dakar been riding for 16 years. LOL
John
Old 09-27-2024, 06:36 PM
Registered Agitator
sgoodwin's Avatar
You would be amazed at what good suspension would do for your bike. Stock truly sucks & wears out early in its life.
Old 09-28-2024, 04:33 AM
DGI DGI is offline
DGI's Avatar
Some progress!
I finally got the bike on the Pitbull Stand.
The belly pan hardware was rusted and one button head allen stripped. That was fun.
Im told factory hardware was torx so I will be sourcing new hardware from the dealership.
The Pitbull stand is way too tall at its highest point. I dropped the arms a couple inches and the bike went right up!
Time for maintenance 🥳
Old 09-28-2024, 07:24 AM
