No try, do or not do
shreddr's Avatar
Originally Posted by ROXTR View Post
I think once I purchase a PCIII I'll be even happier. 12.5:1 pistons could be my winter project .
Purchase and R12S and you'll be ecstatic!
2017 R1200GSW Rallye Shreddr Signature Model
Old 07-30-2012, 01:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Mine (2004 R11S) is also Torx, T50.
Originally Posted by Rick Lee View Post
Yes, mine is torx.
2004 R1100S...1986 R80 G/S...2003 Ducati M800Sie...1981 R100RS (Sold)...1977 Kawasaki KE100 - 1st Bike
Old 07-30-2012, 07:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
I see you
flatbutt's Avatar
Originally Posted by Phil Y View Post
ROXTR, can you give us an assessment of the sprockets. Worth the effort??
it's like a new bike.
Old 07-31-2012, 05:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Phil Y's Avatar
OK, success! Got the bolt out! Busted nut remover and Dremel. Lots of work. Other side came out easily. Go figure.
Now, I think the chain slipped one link on the crank side. I can't turn the engine over by hand. How do I check to insure the valve timing's right?? At TDC, arrows on the sprockets on both sides are horizontal.
Phil Y, Kapolei, HI
04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar
"There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago
Old 07-31-2012, 07:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Rick Lee's Avatar
Whatever you do, don't force it. I may have bent a valve on mine while turning the engine over before realizing the sprocket divet had slipped out of the cam recess slit. I am having it towed to a pro tomorrow. This is becoming a $$ nightmare.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-31-2012, 07:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
shreddr's Avatar
Make sure you keep tension on the chain while you try to rotate the crank or it will just wrap around at the sprocket on the jack shaft. Check out my third hand tool.
Old 07-31-2012, 07:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Whoa, if you start moving the pistons you are in danger of bending a valve!!! If you are in doubt back off on the valves so that they remain closd until you are positive that they are in proper sync with the pistons!!!!!
Old 08-01-2012, 05:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
unsafe at any speed
wswartzwel's Avatar
did you remove the tool you used to lock the engine? dont remove bolt on other cyl until after finishing the sprocket replacement on the first cyl. you have to rotate engine to bring the other cyl to tdc
Old 08-01-2012, 05:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Bill, the way this report reads, I think he did them both without repositioning the second piston to TDC. I hope I'm reading it wrong; but, if I didn't he'd better release the valves to the closed position prior to rotating anything.
Old 08-01-2012, 05:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Regnat populus
boxercup's Avatar
Question PLEASE Limit Failure
Greetings Phil,
Wow you have been through a lot on this sprocket installation.
Failure Prevention is in order now!
I see that you have cam timing concerns but I am concerned about the hard metal filings in your engine.
This is hardened steel that you have filed off the bolt and you do not want this matter floating in your engine causing a serious failure. The picture reveals a lot of filing.
I would address this first.
If you have already made a dam to prevent the above <> boo yeah! Move on to your next step.
If not you must make this your first priority to clean/flush the engine before you turn the engine...
I sincerely wish you a long term positive outcome.
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 08-01-2012, 07:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Phil Y's Avatar
Robert,
Thanks for your concerns. I did create a "dam" of a rag soaked in WD40 and flushed out the area with about two quarts of clean oil (w/the drain plug removed). Anything else you can think of before I proceed?
Now trying to insure the valve timing is set correctly. I was originally able to turn the engine over by hand but when I cranked it, not-so-great-noise. Undid everything and was NOT able to turn engine completely over by hand. I then discovered that right side sprocket was not correctly aligned which led to a dimple on the large washer. Search revealed that I'm not the first one to encounter this issue. Using post #101 on this thread, I set the timing correctly. That was late yesterday.
Plan is to double-check everything, hopefully later today, then try again. Hopefully, nothing's bent!
Phil Y, Kapolei, HI
Old 08-01-2012, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
Regnat populus
boxercup's Avatar
Thumbs up Filter It
Greetings Phil,
Regarding the sprocket that was not seated into the cam correctly after you spun the engine:
I would not worry about a bent valve unless you spun the engine hard and forced it past the piston contact point.
Once you are done you can hear the valves close through the spark plug holes. You can observe the valve clearance, you can do a compression test.
I would flush once more with some kerosene and use a Mr. Coffee type of filter to see if any metal filings are revealed.
Once you are done with the installation I would run the engine and do a quick oil change and inspect the oil.
Precautionary but necessary as you do not want a failure.
Then you will sleep well!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 08-01-2012, 11:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
shreddr's Avatar
once you get it sorted out, make sure you put it in 6th with the sparkplugs out and rotate the back wheel through a number of revolutions to make sure there is no valve clearance issues.
you have certainly gone through a lot to detune that motor which IMHO could use more power not less.
good luck!
Old 08-01-2012, 12:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Phil Y's Avatar
Yep, it's been an adventure that I don't want to go through again! Assuming this will work like many have said, I think it suits my riding style--certainly much more than yours: no track here and can't ride for more than about 1.5 hours without ending up where I started!
Amazed at your builds! Thanks for sharing!!
Phil Y, Kapolei, HI
Old 08-01-2012, 01:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Hehe, you don't need top end in the islands. You'll run into the ocean and the bike is NO surfboard.
Old 08-01-2012, 01:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
lennie's Avatar
Phil,
Something that isin the new instructions and what I emphaisise via the email to confirm postage is to do one side at a time.
Always instll the cam chain tensioner before any movement of the engine.
If you follw my instructions via the email to you then you will be able to check and get it right.
What is the latest as it must have been late there when I replied to the last email yesterday?
Lennie
www.boxer-performance.com
1998 R1100S Yellow is the best (now departed from my life)
Old 08-01-2012, 03:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Do you have any clue as to how this works???
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 08-01-2012, 04:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
As a matter of fact, I do. Give it a rest, ralf. I could ask the same of you for asking such a dumbass question.
Old 08-01-2012, 05:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Phil Y's Avatar
BAD News
I finally got the valve timing correct using the procedure in post #101 in this thread. Before I started, I had cranked out all the valve adusters but when I went to readjust them, this is what I found on the right side exhasut valve. Note that the adjuster is in full down position. This is going to get very expensive. Now, I'm wishing I never attempted this in the first place. Mama's not going to be happy!!
Phil Y, Kapolei, HI
Old 08-01-2012, 05:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Rick Lee's Avatar
I'm expecting the worst with mine too. But if I bent a valve, as long as the headers have to come off, I'm having my guy cut into and hollow out my cat while it's all off. Bike was towed to the local pro today.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 08-01-2012, 06:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
