'97 Boxster O2 connector access..?
Greetings,
How do I access the rear (Cat) O2 wiring connector? Ive read posts and watched Youtube etc. vids but nowhere do I see info on what to do with the wire that runs up and behind the aluminum heat shield. I see a small 8mm nut in that area and am hoping removing that will give access to the connector. Is it that simple or do I have to remove more or do something different?
LLOYD
Old 10-18-2022, 09:32 PM
https://sites.google.com/site/mikefocke2/oxygensensors see the picture with the screwdriver inserted.
If you are removing the sensor from the exhaust, then see the picture of a special wrench.
Any muffler shop can handle the removal, no need for P-car prices.
Old 10-21-2022, 02:24 PM
Originally Posted by Fernando56 View Post
We have been using this for a colossal piece of a time now and it is clearly going charmingly.Thankful for the little by little useful exercise. Has conclusively the ordinary impact!I figure you should check out the sitename support site. MyFlorida Access Login Account
What. The. ****. ?
Old 10-31-2022, 04:42 AM
