I wish I could be Robertson/square head drywall screws.
As far as Philips number 2 power bits go, I always buy Irwin. they seem to fit better and don't round off. |
AutoBahned
Torx or DIE !!
Still here
Shock zone.
I have be replacing all of my stash of 2" and up phillips screws with torx. I just don't have time to deal with phillips.
Counterclockwise?
I think you would pull the sucker all the way to the stud.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
So, to save the rest of us from having to watch him drive a zillion screws, which bit won?
He's a bit over the top, but he usually does very well thought out and detailed tests.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Hell Belcho
You can fix a SAAB with just a set of Torx drivers.
Good stuff
Saved by the buoyancy of citrus. |
AutoBahned
My drywall gun has a torque adjustment so it wouldn't go too deep anyway. Plus I watch how deep it's going in. Why I'd like large head, robertson fitting drywall screws, is because I'm often holding the sheet of drywall up with one hand and balancing the screw on the end of the bit with the other hand. Squarehead/Robertson don't fall off like that and even stay on horizontally.
You can also achieve the same thing (holding a screw) with a magnetic bit. Ain't got one? Get a magnet and magnetize the one you got....
Won't work! In the Southern Hemisphere magnets repel metal screws.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
suffering for decades, rather than succumb to a lowly Canadian invention - the Robertson screw.
AutoBahned
54-40 or FIGHT!!
