Tie rod angle question...
Years ago, when I had a mustang, we used to install offset steering rack bushings or a bump steer kit to level the tie rods for better handling.
When I installed a 3” leveling kit on my 2014 F150 awhile back, my tie rods angle down now. It seems to ride well, but I wonder if it would be better to have them level. I found one set online, but the cost is $600 and I don’t think it would level them near enough. I remember my friend having Robinson Racing in ATL make him some adjustable control arms with heim joints at each end. Would a machine shop be able to make me a set? Mustang bump steer kit. ![]() My truck. ![]() ![]()
I always thought it was ok for the tie rods to angle down some, but it's not ok for them to angle up. The problem is usually for cars that have been lowered so the tie rods angle up.
You might be right. When the car is lowered and the tie rods angle up, toe in is affected as the wheel goes up I believe.
Right, that sounds like what I remember. When the suspension compresses on a lowered car where the tie rods are angled up from the rack to the knuckle, it's bad. If the tie rods are angled down, when the steering compresses, they may go near or to flat, but that's not a problem. I don't remember the exact "bad" result.
Toe is going to be affected whether they go up or down.
In the pictures above as the wheel moves up in a bump the wheel will tend to toe out. You can calculate how much the toe changes. On a truck I would worry about the strength of a rig like the one in the top photo.
. Last edited by wdfifteen; 10-06-2019 at 08:33 PM.. |
Here's some good info from the 911 tech board. There's more in the thread, but these posts seemed to be the most informative to me.
https://forums.pelicanparts.com/porsche-911-technical-forum/436855-do-i-need-bump-steer-kit.html#post4255788 Quote:
Looking from the front of the truck, imagine a circle with its center at the joint at the tie rod end and the rack, with a radius that is the length of the tie rod. As the wheel moves up and down the tie rod end describes an arc on the circle. As it moves through the arc its distance from the center line of the truck changes and the wheel moves in toward the center or out from the center (changes toe) accordingly. Ideally you want the tie rod to be horizontal when the suspension is at its static height.
. Last edited by wdfifteen; 10-06-2019 at 08:48 PM.. |
I think in many cases it is more about the tie rod being parallel to the lower A arm, so they swing parallel to each other. You need to talk to someone who knows about your specific vehicle, but if there is no bump steer or unusual tire wear, you are OK. The bottom line is that you don't want the length of the tie rod to change in relation to the A arm under load or during cornering as the A arm swings through its arc. If the geometry is poor, you want to compensate to try to get them more parallel (or optimal), and you want to align the vehicle while weighted with the most typical load. Obviously that may not be as important in a vehicle weighing 3 tons.
Just from what I see, it looks in one of those pictures that the tie rod and A arm are parallel. . On certain vehicles we used to bend the steering arms to adjust the swing. You should find out what other owners of your vehicle do. I don't think it is a cut and dried, one size fits all solution. If there is no ideal geometry, you want to find out what the compromise solution is, and do what works best. Last edited by DanielDudley; 10-07-2019 at 02:56 AM.. |
Thanks guys. The top picture is one of a Mustang with a bump steer kit.
The bottom two pictures show my control arms with the tie rods parallel to the A arms. Tire wear is good and most of my driving is highway with no off road (it’s 2 WD and I just wanted a slight height adjustment with slightly bigger tires). |
The discussion about 911 suspension is good as far as toe changes go, but the 911's McPherson trust system is very different from your truck's double A arm suspension. Camber geometry is different.
if you want to determine the proper angle of the tie rod then you have to calculate the instantaneous center (IC) of the suspension.
then the angle of the tie rod needs to tie into the IC point. that way all 3 lines are moving one the same arc of the IC.
Still Doin Time
From the pics above - your angle from the inner tie-rod pivot point is too far down (vertically measured) in relation to both upper and lower control arms. With the truck on a level surface, wheels ahead - the tie rod assy should be close to the same plane as the lower control arm.
And of course - it isn't . MO is the best way to resolve this is (hopefully) someone makes an aftermarket steering knuckle that places the tie rod arm higher so the angle is not so extreme. I'm sure there is someone out there that has these as lifted trucks are very common place. I'm not a fan of those tie-rod end extender's - unless they are the only solution and very short - like 1" or less.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
The real solution is to install a proper lift of 4-6” for $1,000 plus. With a revised knuckle and K member, it raises the truck while keeping the suspension geometry correct.
For $100, I installed a leveling kit, which amounted to a front strut spacer and rear axle block. It’s basically at stock 4 WD height now, which is all I wanted. One day, I might install the 4” lift... Quote:
Still Doin Time
In this situation a revised knuckle is all he needs.........
