cycling has-been
bkreigsr's Avatar
Help with sprinkler heads
Brand new system - the installer/tech demonstrated how to adjust the coverage area and water flow volume. I'll be damned if I can do it.
I have several zones that overlap and would like to reduce the output of the opposing heads in the zones so they don't give me double coverage.
any who - here's the head and various markings.
He gave me a white plastic tool to insert and twist, but yesterday all I accomplished was getting myself soaked. I think he also used a very small screwdriver to reduce/increase flow.
Any help would be appreciated. Thanks in advance. Bill K
Old 08-30-2023, 02:22 PM
cycling has-been
bkreigsr's Avatar
Aforementioned 'tool'
Old 08-30-2023, 02:27 PM
A930Rocket's Avatar
Baz in 3, 2, 1….
Old 08-30-2023, 02:42 PM
https://www.hunterindustries.com/support/residential-rotors-adjustment-instructions
Old 08-30-2023, 02:50 PM
You do not have permissi
john70t's Avatar
Grab a glove and a tub of heavy grease. Coat every fitting. And the rest of it.
Old 08-30-2023, 04:32 PM
Information Overloader
I had never even come close to considering this, which is not unusual.
Great advice!
Old 08-30-2023, 04:42 PM
Canucks Fan
Mine is quite similar and the screw that holds the spray nozzle in place can also be screwed down further to enter into the stream of water to help spread the spray pattern.
Finn
From the Deep Dark Jungle
Old 08-30-2023, 06:19 PM
cycling has-been
bkreigsr's Avatar
Thanks red 928.
That must be the video the tech told me to look at.
The operator makes it look so simple.
Old 08-30-2023, 06:24 PM
cycling has-been
bkreigsr's Avatar
Thanks...but the system, with all 27 heads, is already buried on the property.
I'm guessing that the lube operation is something that the install team does not perform ?
Old 08-30-2023, 06:28 PM
If you are still having problems....call the installer and ask if they can stop by and help you. Most contractors would do this if asked.
Old 08-30-2023, 06:32 PM
Hey Bill......in a proper spacing......the spray radius of each head should reach the head(s) of every other adjacent head.
In other words....the streams of water should overlap each other.
That is because of the trajectory of the water stream...to ensure proper coverage overlap is needed.
So maybe your system is adjusted right.
In any event - your contractor can help you with any questions you have. If it's a brand new system he'd probably not mind coming by just to double check his own work. In a perfect world.....
Old 08-30-2023, 06:39 PM
cycling has-been
bkreigsr's Avatar
Question - does the head need to be elevated for the adjustment to take place?
Does the water have to be flowing through the head?
Old 08-31-2023, 10:03 AM
Yes - should be running......don't break the heads!
Old 08-31-2023, 10:13 AM
Bill - quick followup to clarify. These are gear driven heads. And as such, the gears are subject to damage if the adjustment process isn't handled properly and carefully.
If you are not certain about what you are doing - please do not proceed.
As I said before....contact your contractor and ask if he can come back by and help you understand how your system is set up design wise and also any adjustment instruction. It's not all that hard but better when someone shows it to you in person.
Thanks!
Old 08-31-2023, 02:58 PM
