-   -   Engine Porn (http://forums.pelicanparts.com/showthread.php?t=622390)
URY914 02-23-2020 04:43 PM
http://forums.pelicanparts.com/uploa...1582505024.jpg
URY914 02-23-2020 04:44 PM
http://forums.pelicanparts.com/uploa...1582505051.jpg
URY914 02-23-2020 04:45 PM
http://forums.pelicanparts.com/uploa...1582505082.jpg
Racerbvd 02-23-2020 06:20 PM
http://forums.pelicanparts.com/uploa...1582510768.jpg
Racerbvd 02-23-2020 06:24 PM
http://forums.pelicanparts.com/uploa...1582510843.jpg
Racerbvd 02-23-2020 06:26 PM
http://forums.pelicanparts.com/uploa...1582511101.jpg
Jim Bremner 02-25-2020 10:17 AM
Originally Posted by RWebb (Post 10693202)
http://forums.pelicanparts.com/uploa...1576727824.jpg
this 4.6L V8 weighs less than 300 lb. (a LOT less than our flat 6's) and makes 600 hp with 400 ft-lb. torque
What engine is this?
I'm thinking of building a Lotus 7, the turbo isn't needed but a 300# V8 sounds great! I've been thinking of a Lexus 1UZ-FE the last version had variable valve timing and 300 or so hp at 320 pounds
Racerbvd 02-25-2020 10:31 AM
http://forums.pelicanparts.com/uploa...1582655461.jpg
RWebb 02-25-2020 12:43 PM
that is an engine for a hybrid car...
a 918
daepp 02-25-2020 02:11 PM
Originally Posted by URY914 (Post 10762107)
CAn anyone ID these engines? I'm just gonna guess that the center is a 427 side oiler.
asphaltgambler 02-25-2020 02:37 PM
The two blue and red on the left rear are Ford SOHC engines. The right rear one appears to be SBF with an overhead cam conversion. The front left some road race / inspired Ford engine.
The SOHC engine were a real innovation in their day as the cylinder heads had machined intake and exhaust ports as well as combustion chambers. The only production engine ever to have that level of finish machine work. It also was designed from the beginning as a high RPM with extended use.
Zeke 02-25-2020 03:02 PM
Upper left Hemi 302 (experimental); lower left Indy turbo; center 7L experimental Le Mans; upper left , as mentioned, experimental SOHC; and the last one is a Boss 429.
As shown on the cover of Hot Rod Magazine, June 1968
https://www.picclickimg.com/d/l400/p...-June-1968.jpg
URY914 02-25-2020 05:06 PM
http://forums.pelicanparts.com/uploa...1582679199.jpg
URY914 02-25-2020 05:24 PM
http://forums.pelicanparts.com/uploa...1582680271.jpg
Jim Bremner 02-25-2020 05:43 PM
a 918
Yeah, that's out of my price range a scoch
URY914 02-25-2020 06:27 PM
http://forums.pelicanparts.com/uploa...1582684088.jpg
rusnak 02-25-2020 06:30 PM
The block maybe weighs 300#s. But the exhaust system looks to weigh a lot more than that.
GH85Carrera 03-09-2020 09:47 AM
http://forums.pelicanparts.com/uploa...1583772390.jpg
Some nasty engine porn! :eek::eek:
bkreigsr 03-09-2020 10:42 AM
Now that the engines have been id'd, can anyone id the dudes?
I'm guessing The Duce, and Phil Remington ?
Racerbvd 03-09-2020 02:17 PM
http://uploads.bmxmuseum.com/user-im...5e66b21f1c.jpg
http://uploads.bmxmuseum.com/user-im...5e66b2312e.jpg
http://uploads.bmxmuseum.com/user-im...5e66b2441e.jpg
http://uploads.bmxmuseum.com/user-im...5e66b257ba.jpg
