Un-Registered User
No water in either panel? Is this a single rental or are there other units on the main service.
Don 1988 Targa Last edited by Red88Carrera; 12-07-2011 at 06:27 PM.. |
I don't see any (water or critters/droppings). The main is on an exterior wall, the secondary is in the garage.
Good idea on throwing the breakers. I'll wait until Shirley gets home so she can tell me which ones are going out. Not that I don't trust the labeling
You do not have permissi
Just an idea- I thought the grounds are attached to water pipes inside and/or copper rods in the ground outside.
Meanwhile other things are still happening. |
sounds like you are losing a leg (feeder). if it was the neut then the whole house would flicker and from your description it sounds like multiple circuits. in my mind what is happening is that whatever you are doing is creating heat which opens the connection, the power ceases to flow and you are left without power until the connection cools and resumes contact. i have a feeling that when this is found, it will be quite evident. good luck.
Chris the more i learn, the less i know |
Un-Registered User
If all the bad devices are on the sub panel it could be a bad neutral. Either way, it's a loose/bad connection.
Don 1988 Targa Last edited by Red88Carrera; 12-07-2011 at 06:37 PM.. |
There are a small number of outlets that don't seem to be affected, but there have been some times where every light in the house has flickered (though not completely power cycled). So this likely is an issue at the box rather than in the walls/ceiling? It affects so many of the outlets/lights I'm assuming it would have to be at a somewhat central location. |
If you really want to get into this we can. first what you need to do is figure out what circuit(s) the problem is occurring on. as in which individual breakers and which panel. if you are talking more than one circuit it would go back to the panel, if it is from both panels then you are talking either the fire switch (main breaker outside) or even the utility. if you are have problems with only one circuit then it is definitely possible that it could be happening in the walls, the more widespead the problem the less chance of that.
It is more than one breaker - that much I know. And if I believe the labels it is on both the main and sub. But I don't know that I believe the labels. I'm home alone at the moment so I can't do the experiment of throwing a breaker and seeing what goes out. Sounds like it is at the panel though.
plug a radio in and turn it up so you can hear it cut off.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
UnRegistered User
Aluminum wire?
Can be trouble if not maintained or the wrong breakers/switches/fixtures used with it.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
i have to hit the sack but if the problem does happen tonight listen, with the cover closed, for any popping or snapping sounds. my first place to listen would be at the main panel especially since the meter is right next to it. you have four connections that i am suspecting without more information. the main breaker connections ( not visible in your photos) the line and load of the meter socket and the taps (where the utility meets the housing wires. don't go moving wires in the box as it could make the problem worse. i'll check in the morning.
She (the landlord) is just clueless. I knew that moving in though. Since her electrician didn't show and hasn't called I'll give until noon tomorrow at which point I'll call a guy that one of my work colleagues uses who knows his stuff. And whatever he charges to take a look will be deducted from next month's rent, and then I'll tell her that either her guy fixes it immediately or I'll pay my guy and deduct that from the rent as well. That's what I had to do to get the garage door fixed.
Always something... |
Banned
Could this have anything to do with the high winds last week. You're in Santa Monica, right?
I think several thousand people in LA are still without power. Maybe it's Edison and the grid, not your house specifically. Has it been going on for more than 6 or 7 days. That was when the winds screwed a lot of thing up. |
Red88Carrera has had this nailed all along. In his panel it's the center lug with the 3 large wires coming down. The service cables are almost always AL and get loose. Now, Todd, I know you're not going to grab your 3/8ths Allen wrench and bear down on that sucker, but that's all it takes. Make sure when your guy shows up that you video him putting a turn on that. Give his bill to the landlord, don't deduct. He can collect if he has to, but the video should take care of it.
Do the feeds in the sub panel too. BTW, a power company guy told me (in another state where I was working) to tighten down the lugs after 30 days on a new service. Yeah, right, Bubba. There is no disconnect in front of the meter and you have to pull the meter to disconnect the load side. Not me. |
As others said don't do anything on a live circuit, it can KILL you, unless you know what you are doing
Dollars to donuts a bad connection on one leg of the feed line, or a bad main breaker, if it was the neutral it would effect all circuits (except 220v). It could be at the meter, main disconnect or at the main breaker in the panel. One sure way to tell is if the effected circuits are served by every OTHER breaker. One word of caution, don't just check the tightness, as the screws can seize and appear tight, LOOSEN first, then re-tighten to be sure.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Senior Member
Nostatic is not going to be giving any boxes the haircuts they need, but he could just make sure the connections are tight. A good electrical connection is all about having a 'tight,' airless connection. To get that, you compress metal onto metal. Just see if those big screw connections are tight. Aluminum wiring is notorious for shrinking and becoming loose. The big multi-strand stuff like incoming power should be coated with that anti-oxidant stuff and screwed TIGHT. Then again, I didn't sleep at a Holiday Inn last night.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
1966 - 912 - SOLD
all work shall be done in a neat and workman like manner--- this is what they are talking about----
i was too tired to be pretty last night! |
Senior Member
This needs to be fixed and now. My first gut feeling was also the neutral side...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
