Parrothead member
( except my own work of course.. ![]() ) Beautiful work!
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I could repost Red's lovely service panel picture again for this question to him. Why did you route the three phase (large) conductors to the top of the panel/box - could the breaker frame be inverted to make your install Even Cleaner?? Or does the box require the orientation to remain this way??
If the problem is not loose main connections this box needs to be stripped down and cleaned up or better, replaced. You referred to it as a new box - but its pretty old and crowded. Time for a new box. My bet is that the box connections are deteriorated, pulling the breakers will show the corrosion. I replaced DIY a pool subpanel that went south after 35 years - it was creating lots of heat from poor connections behind the breakers.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
Seldom Seen Member
Wow. Ordinarily I am impressed with the PPOT brain trust, but not this time. Have you seen "Paranormal Activity" I or II?
Why do things that happen to white trash always happen to me? Got nachos? |
You do not have permissi
Send a same-day certified letter to the LL of occurances, past communications, and note pictures/witnesses/etc. Let her know it is her property and business that is being affected.
Call and confirm. Do the nice human thing. If no immediate response, call another electrician to fix pronto, then deduct in writing from rent. Done.
Meanwhile other things are still happening. |
It is true that the musical equipment could pull enough to start some arcing on a system that had low use for a long time. However, that is not the tenant's problem. Only if the system is healthy and the tenant keeps popping breakers is the tenant over loading the circuit(s).
I would make this point as well. |
Puny Bird
1/ I don't like how it's between the studs. 40 years from now the panel will need to be replaced, what if you can't find a panel that is as narrow as the one you have. 2/ The manicured lines look pretty, but again if the panel needs to be replaced what happens if your lines come up an inch short in the new panel? This is reason #1 why I leave my wires long. 3/ I really don't like how the top lines run down to the top half of the breakers. Reason #2 why I leave my wires long is all the wires entering my panels make a loop down then back up to the breaker. The reason for this is if there was ever a leak in the house and water followed down the wires it's going to flow right into the breaker. The loop will make any water drip harmlessly into the bottom of the panel. This is a pic of the 100amp panel in my shop, the panel in my house looks similar and is the same brand (for interchangeability of breakers) except it's a larger 200amp service. Not as neat as yours, because every wire is long and makes the downward loop. I installed this panel about 15 years ago, since it's in my shop all of the outlet wiring is 12/2 with 20amp breakers. BTW I was the first reply with "Check and tighten all your terminals", although some have said it in more words. I was taking this pic so I decided to tighten all my terminals, as I do almost every year and many were slightly loose.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 12-08-2011 at 12:39 PM.. |
They allow exposed Romex up there? I can't really see, but they look like Romex. I did not read all of the stuff here, but back to Todd's issue, there's a slightly loose wire somewhere. I'm thinking its one of the neutral wires to a particular breaker. I would tighten up the main wires with that big fat Allen key.. |
171, I'm still leaning towards a leg out. From what i have read, the problem is on multiple circuits from multiple panels.
Chris the more i learn, the less i know |
Un-Registered User
Don 1988 Targa |
I was under the impression it was a few lights were coming in and out. Heck if its multiple circuits, then it has to be a loose leg. It can't be anything else.
For clarity, that is NOT a 3 phase system, it is a standard 220V panel, 2 hot legs, and a neutral. Red your installation shows you take pride in your work, but as MH suggested, I always put a U-loop in the wires, not so much for water, but so I have length enough to move breakers up and down in the box. I am frequently appalled at the sloppy wiring being done in new VERY expensive homes, constructed by some of the mega nationwide home builders, along with poor foundation and for that matter, most of the work. Best I have seen recently was in eastern Ohio where the Amish or Mennonites, were doing a lot of the construction. You could drive through the subdivision and tell from the road, which homes they were working on.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
Small update. The landlord got ahold of another electrician who will come out tomorrow AM (turns out the first one went out of business - shocking). He suggested I call Edison and have them check to see if there was a problem between the pole and the box. The Edison guy called me after checking and at first said it looked ok on their connection at the house. He asked me if it was multiple circuits flashing/going out and I said yes but it didn't seem to be one board or the other but a mix of outlets/lights. He said that he would need to climb the pole as it sounded like maybe it was a bad connection there. He said that an oxidized connection at the pole can cause every other circuit on the breaker board to go out. Odd - never heard that one before. Haven't been home yet and didn't hear back from him after he went up the pole.
I am finishing up a small house for a woman in one week. I believe I am the third contractor. She's suing one of them. The one before can't product the detail she is looking for. The owner is a real pain the azz and micro manage everything up to the shoe molding. I am fine with that, but she's willing to pay for it. Most contractors just want to bid low, get it done and get pay. If you continue to do that, its fine, but you will always get that kind of work and pay. That's ok too. |
UnRegistered User
Some exceptions can apply.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Puny Bird
100% code and inspected. Quote:
BTW besides my shop I've also replaced my house panel, moved my meter base (disconnect required) and wired my garage (I have a shop and a garage) each one is a separate 2-part inspection. 3 times the inspector didn't even come back to do a final inspection including the meter base. I also have 2 DV fireplaces, DV furnace in the shop and a stovetop, all propane and installed by myself. I built the shop and attached garage, but the house was here.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 12-08-2011 at 05:24 PM.. |
Un-Registered User
If the white wire is a conductor, it needs to be identified by a marking onto itself. Is there a marking on it that is not visable in the pic?
Don 1988 Targa |
No Band
Hey Todd,
Not trying to freak you out, and I am sure the electrician will find the problem, but the last person that I knew of that was having these kind of issues was on their brand new home. It took about three years but it eventually started a fire and destroyed part of the home. What was found to be the culprit was a short caused by nails that were nailed in through wiring/insulation when they were putting up the sheet rock.
He was a helluva plumber and his outfit was self explanatory |
