DIY Powder Coating
I want to introduce myself, I write for a a DIY powder coating site. I have been powder coating for several years now and I just made the site to make it easier for other new powder coaters to get started.
I started powder coating parts for my car restorations and the results have been amazing.
Anyways, if anyone else here is interested in powder coating or already is into powder coating, you might want to check the site out. Powder Coating: The Complete Guide
I just finished an article on How to build your own powder coating oven.
Also, feel free to ask me any powder coating questions, I would be happy to answer them.
I have coated hundreds of parts at this point with a relatively low budget, here are a couple of them.
Old 07-06-2015, 09:30 PM
I bought a kit and coated some parts for my 911
the results were great
Old 07-07-2015, 10:59 AM
Years ago, at least 10, I went to a tech day at a guys house with the PCA for a guy that had done a bunch for a Ferrari restoration and some on his 911. He also did a piece or two while we were there. He'd picked up an electric oven (kitchen style) from a yard sale for $50 that he used just for that purpose.
The results were pretty impressive, even on a piece that was too large to fit completely in the oven. He did half, then flipped it around and did the other half.
Old 07-07-2015, 11:42 AM
300hp 1800lbs is the goal
pksystems's Avatar
Nice. I see some mitsu parts.
Old 07-07-2015, 11:52 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
I picked up a DIY gun on eBay a while back. Got it for less than $50 due to it being damaged in shipping. Took about an hour to repair it an its work flawlessly ever since. I converted the top shelf on my storage rack into an oven using insulation from Home Depot, a double element hot plate and a digital thermometer from the grocery store.
Old 07-07-2015, 01:06 PM
What did he do about the door being open?
Back in my earlier powder coating days, I powder coated the brake lines and fuel lines that ran from the front of my car to the back. About 10 feet long. I used a propane grill and did a section at a time running the lines through the rotisserie slot in the grill hood. Definitely not ideal, but the seams blended pretty well. It was a 2 coat job so it took me all weekend to do it.
Old 07-07-2015, 05:19 PM
Good eye. All the parts belong to a 3000Gt VR4 except the calipers which I did for a friends base model. They are for the car I have been restoring.
Old 07-07-2015, 05:20 PM
That is really neat, how much did the materials cost you?
Old 07-07-2015, 05:23 PM
1.367m later
KevinP73's Avatar
Double burner hot plate was ten bucks at a thrift shop, the insulation was less than twenty for an 4X8 sheet of the good stuff. I was concerned about the heating elements sitting directly on the insulation so I went to Industrial Metal and got a piece of aluminum that measured the same as the shelf but even that was cheap. All in I didn't spend $100 on the whole set up.
Old 07-07-2015, 07:21 PM
wtf would you do your own powder coating? I take my rusty wheels and whatever to a guy who sandblasts and powder coats my parts and has them done the next day for like $100 for each batch of parts. I couldn't come close to the quality he does, either.
Old 07-07-2015, 07:55 PM
Friend of Warren
Kevin, that's pretty damn ingenious!
Kurt V
Old 07-08-2015, 05:48 AM
TheSt|G's Avatar
I think the issue is a lot of people spend a ton of money for powder coating. My guy charged me $4.60 for each my of front/rear suspension components(A-Arms, sway bars, etc) for blasting and powder, but I know that is well outside of the norm.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 07-08-2015, 08:33 AM
Now in 993 land ...
aigel's Avatar
Strange comment on an DIY site.
You can cut a check for every restoration or auto repair job. It is always easier and often a wash in terms of cost. But do you want to do a checkbook restoration? We all pick things we like to do ourselves and things we don't.
Do you brew your own beer? Bake your own bread? Grow vegetables? Cook for yourself?
G
81 SC (sold)
Old 07-08-2015, 09:19 AM
1.367m later
KevinP73's Avatar
Thanks. As they say "poverty is the mother of invention ".
I'm constantly doing little pieces here and there. It would be impractical for me to run to the powder coater every time I have a little bracket to be done. Plus, it keeps the loss of little parts at zero for me. Big pieces I don't worry about but some little hard to find part getting lost at the pc shop can be a real problem.
Old 07-08-2015, 09:24 AM
That is awesome. I don't know much about those hotplates but I am surprised they can heat that box up to 400+ degrees. Thanks for sharing it.
Old 07-08-2015, 10:04 PM
When I started my restoration 6 years ago, I was spray painting parts and realized that it wasn't going to hold up for very long. I took in a bunch of parts to a powder coating shop and was quoted $1000 for the batch. I decided to go the DIY route, spending less than $600 on a powder coating gun, air compressor, blast cabinet, and household oven. I have since coated 5 times the amount of parts I originally brought in and while my quality at first wasn't that great, through tons of trial and error, it became excellent.
At this point, it isn't even about the money saved, there is just a satisfaction about doing everything myself that I enjoy. Plus I learned a new skill.
Old 07-08-2015, 10:12 PM
Any other powder coaters here?
Old 07-12-2015, 07:40 PM
pksystems's Avatar
I'm using Eastwood dual-voltage, and a extra large propane oven. I use an extension on the oven for extra large (sway bars) items.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 07-12-2015, 09:27 PM
Id love to DIY, but the only thing I've got that needs powder right now is the roof rack for my bug. Too big for a home oven.
Old 07-12-2015, 09:40 PM
I would really like to do my door handles....
Old 07-13-2015, 04:45 AM
Tags
powder coat , powder coating , powdercoat
