77 Restorer
Sorry to hear of your tribulations on getting a dyno run - I'm actually amazed how difficult it is, so I assume there is alot of maintenance and/or tech costs that make it prohibitive. I guess the iterative trial and error approach may continue for a bit of time for the both of us. For the time being I'll be out there in the mornings on the weekend recording and analyzing and making tweaks based on my 7000+ ft altitude.
Bert 77 911 Targa (Maize, or Talbot yellow as the case may be) 04 C4S Cabriolet (sold) |
Hi Bert,
We have dynos all over the place here, but they are only tuning American iron or Subaru. I haven’t given up yet.
Rutager West 1977 911S Targa Chocolate Brown |
If anyone is still following my “adventure”, I am starting to feel like I’m making progress now.
When I first put the system in, I didn’t get any advance showing on my timing light, but since I was new to this whole electronic ignition and the internet was saying that many timing lights won’t work with EDIS, so I just assumed it was advancing and you know what they say about assuming? Another thread got me thinking again about the advancing or lack thereof. I reached out to Jamie Novak as he had responded to that thread and made some interesting points. So between Jamie, Al, myself, my timing light and my oscilloscope, we concluded that the ECU wasn’t right for my car- Al immediately sent me a different unit (this is exactly why I bought my system from him!) and now I have advance. Jamie also noted that it appeared my ITBS weren’t balanced at higher RPMs- my flow gauges proved him right- I had thought that I had gotten them balanced originally, but apparently I hadn’t or something changed the setting. A test drive afterwards really felt much better and is helping me get my eagerness back- I think I was actually getting depressed by tuning, driving, tuning, driving and never getting anywhere along with zero luck finding a local dyno tuner.
77 Restorer
Best, Bert
Hi Bert,
If you hook an oscilloscope up to the SAW output on your EDIS you should see a 0-5v square wave that changes with RPM. I had the waves, but they were going negative, so still didn’t work. Here’s my photos of the scope- the lines should have been going up not down like they were. I haven’t actually put the scope back on, but my timing light now shows the same advance as the computer says- it didn’t move before. ![]()
77 Restorer
Bert
Hi Bert,
I’m not going to be useful in answering the coil on plug output question. I’m using EDIS, which is a Ford ignition system that uses coil packs and one of the outputs on a EDIS module is called “SAW” and is responsible or reports advance. I don’t think COP has a “SAW” output, but I could be wrong. Have you hooked up a timing light? I’m not even sure how you do that on COP, though. Sorry I couldn’t help you, Rutager
77 Restorer
Thanks again, Bert
COPs spark plug extender
Bert,
If you use a spark plug extender wire and hook your timing light to it, you will measure timing just fine. You just cant hook a timing light directly to the COPs wires as they are low voltage, triggering the ignitors. plug one end onto the sparkplug and the other into the COP and clamp the timing light on the cable and .....let there be timing light regards, al PS: No SAW signal with COPs, that is EDIS specific....Make a simple spark plug/cable extender and you will be able to verify timing with no problems.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 08-29-2022 at 05:09 PM.. |
I just hook up my timing light to the wires going to the COP - works perfectly. Even works on both my kids RAV 4s and my Landcruiser. Timing light flashes like a dream.
77 Restorer
Best, Bert
77 Restorer
Bert
timing
Bert, the extender works perfectly. If you can please provide the link to where you read that there is an issue using that method, I would like to read it. I've used that extender method, starting with my 1st COPs installations of Rasant systems, as well as motec, M'squirt etc. basically all of the COPs systems i've worked on.
Note: some timing lights will pick up logic level signals, which is what the MS3X and other systems use to trigger the coil ignitors, others do not and require the extender.. regards, al Remember, your crank trigger system just requires for you to check initial timing to ensure sync and that the M'squirt initial timing setting matches the actual timing, as verified by your timing light. I set the ignition advance to "fixed" timing at 0 degrees and verify with my timing light. The tooth #1 angle is used to dial in the timing. I.E. to set the timing at TDC. Once that is verified, you change the timing back to "Use Table" and then the timing chart controls the timing/advance......and, you can use your timing light to double check that the timing is following the chart and advancing per the chart. You have your engine running....so this part of the process must be well underway.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
77 Restorer
Yes, this is exactly the way I did it, based on our conversations which seem so long ago. I did check the initial timing for synch at TDC at tooth one, but after setting it to use table and revving the engine, I just don't get a good consistent signal from my timing light. I tried changing to an inline spark tester just to see, and results were poorly consistent. My review of the logs shows timing advance happening. I don't have the link about the timing measures, but my notes suggest that setting the timing with the dial and reading the alignment don't work since it's the time between sparks to compute engine speed and advance, but wasted spark doubles that amount per rpm so is inaccurate. Again, I may have misinterpreted this, but it suggested to me my measures (or lack thereof) were in doubt. I haven't had time yet to recheck my system the suggested ways in this thread, but will do so and report back. Thanks again for the help. Best, Bert
We’re teaming up on this install and between Jamie and Al’s help, this EFI is starting to sing. Thanks, guys.
There is still much tuning to do, but now each time I drive it, I can tell a difference. Did another run today and I still have some real rich and and real lean sections, but only a few backfires/misfires although one was pretty loud. I took it out of the neighborhood (where I can only drive around 20mph, because I’m not that guy!) and got on a road with a 45mph limit and put the pedal down and ran it up to 4,000RPM, okay that’s more what I was thinking ITBs would do. Another note is that my oil temps seemed to be lower, outside temp was about 80F and I think I drove for my normal amount of time and saw about 20 degrees lower.
77 Restorer
No, not yet. I was hoping I didn’t need to as it doesn’t have a thermostat, so on cooler days it takes the engine longer to heat up. The cooler is just a long aluminum tube with fins that is cut into the “S” hose to the oil tank. Seems to do a decent job though. With removing all the grease and grime from the engine, cutting the tins like the later cars, sealing the shroud openings, having better control over AFRs and ceramic coating the exhaust, I was hoping temps would be reduced. Time will tell...
77 Restorer
Jamie sent me a procedure to work on the VE tables RPM ranges one at a time over their MAP ranges. In hindsight, I think Al also mentioned this to me, but at that stage in my understanding, It just didn’t click- sometimes the right information also needs to come at the right time!
So, I went out early enough to find some traffic free roads in farmland, but not so early to disturb the neighborhood- although I have stock exhaust and I don’t think my car is too loud, my driveway also goes right next to the neighbors bedroom window. The procedure could be called a poor man’s dyno- you set the auto tune setting to be active, then drive the car at each RPM column and slowly add brake while maintaining the RPMs so the computer “sees” the full range of MAP for each RPM so it can adjust each cell. I also had some good roads in the sense that they were rolling, so I could also get different MAP just from downhill engine loading. The car does seem to be getting much smoother- I have more work to do, but roads started to get too busy to continue safely.
So interestingly, auto tune seems to screw up my lower RPMs- loves to turn up the gas at idle to pig rich and lean out low map settings. I set the auto tune to ignore below idle, but should have gone one more column up.
So, another good and another bad thing on my more than hour long 50+ mile drive. Good was that my temp never exceeded 210F and that was during my hard efforts- normal driving was under 200F, but it was also only 60F outside temps! Bad was I heard a bang on the passenger side that didn’t sound like an engine misfire... and it wasn’t, something must have launched from under my front wheel and hit the passenger door leaving a couple inch scratch to primer- doesn’t appear to be a dent, luckily.
