Bonjour,
Je suis en France et là aussi le manque d’information est incroyable….
Mon moteur est un 3.0 en CIS et j’ai un 123 ignition Bluetooth . J’arrive à rentrer et programmer ma courbe. Par contre je me prend la tête avec le retard à dépression. La Map n’accepte pas de valeur négative. Comment contournez vous le problème…
Merci d’avance
Old 11-11-2025, 10:01 AM
Smile
Personne pour m’aider….
Old 11-13-2025, 05:05 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Need to state whether it’s a T, E or S .. different curves for different engines.
Old 11-13-2025, 11:03 PM
Originally Posted by range83 View Post
Hello,
I'm in France, and here too, the lack of information is unbelievable…
My engine is a 3.0 CIS, and I have a 123 Ignition Bluetooth adapter. I can enter and program my ignition curve. However, I'm having trouble with the vacuum advance. The map doesn't accept negative values. How do you work around this problem?
Thanks in advance.
No one to help me…
I've been trying to find information more on the map side of programming too without much luck. Every thread, old or new, seems to only go over the ignition set up, mentions the map will be next, and then never covers the map side of things.
Old 11-14-2025, 07:33 AM
Bonjour,
C’est un carrera 3.0 de 76
J’ai la courbe, mais je n’arrive pas à rentrer de valeur négative pour l’avance à dépression qui est si particulière. Je sais qu’il y a une astuce, mais je ne trouve pas réellement la solution.
Merci d’avance
Old 11-14-2025, 11:05 AM
Arrow
Bonjour,
Merci d’avance
I think that you want to advance timing, so you are adding degrees, no need to add negative values. Vacuum advance helps the engine run smoother, cleaner and more economical at light and partial loads.
Drive the car while monitoring the app dashboard and record the max kph value at light cruise about 3200 rpms. The max value will vary at light cruise and other load conditions.
Set the app to ignore MAP below 2000 rpm. Then add 10-13 degrees of advance to cover the kph values.
If you want to retard timing anywhere in your centrifugal curve then you have to set the distributor static timing at a negative value to start, then write your advance curve with that in mind. So if you set your static timing at -5 degrees then when the app shows 20 degrees it will actually be 15 degrees.
To set a vacuum retard 123 calls it a vacuum retard trick, see directions at https://123ignition.com/support/create-curve-tutorial/
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Last edited by snbush67; 11-27-2025 at 05:48 PM.. Reason: Set the app to ignore MAP below 2000 rpm
Old 11-21-2025, 08:49 PM
Set the app to ignore MAP above 2000 rpm. Then add 10-13 degrees of advance to cover the kph values.
Shane
Merci pour vos explications je vais regarder celà. Et je reviens vers vous…
Old 11-27-2025, 01:08 PM
Arrow
Note that I made a mistake but have corrected it in my post.
Old 11-27-2025, 05:49 PM
Merci, je l’avais vu. Je suis allé dans l’application pour voir si c’était bien dessus ou en dessous.
Old 11-28-2025, 08:02 AM
