I wonder if the 'dip' might have something to do with the large jump from 1.5inch to 1.75 inch headers?
Perhaps a set of 1&5/8 might help?
Always learning.
www.aircooledporsches.com.au
Old 08-07-2024, 09:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #241 (permalink)
Racer
winders's Avatar
The 1 3/4" headers are way too big for that motor. He should be using 1 1/2"...1 5/8" is also too big.
I don't recall if we heard how big the ITBs are....and the stacks are short which doesn't help the lower RPM range any.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-08-2024, 12:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #242 (permalink)
I have said that at least 2 times in this thread but what do I know? Only made 300 sets of headers for clients over the last 9 years
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 08-08-2024, 09:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #243 (permalink)
Originally Posted by dannichols1474 View Post
Okay, I ordered some smaller diameter headers. I like Bursch headers as I have been using their products for 18 years, so I ordered their 1 5/8 inch headers. Once I get them and install them, I will do another round on the dyno and see how this plays out. You'll see the data here.
Winders and MB911: Show me your data.
Simple search
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-08-2024, 02:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #244 (permalink)
More talk.
Hmm sorry thought a pictured attached but it didn't hold tight. in the meantime here is a good read.. I can guarantee you as prove the 1-3/4" is to big and 1.625 will be borderline too much and 1.5 would be just right but again as the former owner of M&K exhaust and my aerospace work previous I am not just some dummy spewing ideas from my couch. I interreacted with hundreds of dyno shops and end users over the years. I would encourage you to call Marty and MSDS and see what he says. That is one of the last still USA made Porsche header fabricators amongst many other automobiles. He owns #40 914-6GT that was raced in Le Mans and has many other wild cars. Call Supertec. Talk to Henry and he will tell you the same. Call Brian at M&K/Rarlyl8 he will tell you the same. https://forums.pelicanparts.com/911-engine-rebuilding-forum/487943-sneak-peek-new-stainless-steel-headers.html
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-08-2024, 03:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #245 (permalink)
simple google.google.com/search?q=header+primary+size+chart&rlz=1C1GCEB_enUS938US939&oq=header+primary&gs_lcrp=EgZjaHJvbWUqBwgDEAAYgAQyCQgAEEUYORiABDIHCA EQABiABDIHCAIQABiABDIHCAMQABiABDIHCAQQABiABDIHCAUQ ABiABDINCAYQABiGAxiABBiKBTINCAcQABiGAxiABBiKBdIBCT g2MTRqMGoxNagCCLACAQ&sourceid=chrome&ie=UTF-8
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-08-2024, 03:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #246 (permalink)
mb911 thank you for all that info.
I went through the link to the earlier forum thread and saw all of the dyno plots and the table of various exhaust configurations versus hp at 3000 and 6000rpm.
I also read several other earlier posts about header tube sizing. One thread from 2004 mentions ID versus OD. I just measured a primary tube OD on the 1.75" headers currently on the car and it measures 1.75" so when we talk about 1.50" or 1.625" headers we are talking OD, right?
That same thread also mentions camshaft specs being a factor in addition to engine displacement for determining the correct header primary tube size. The idea was that engines with "bigger" (more duration and lift) cams would benefit from larger headers.
So my now 2808cc 2.7L motor (92mm vs stock 90mm bore) with 69-73 911S MFI cams (duration: 264/236, lift .450/.402) versus stock CIS cams (220/200, .410/.348) still should have 1.50" headers versus 1.625" headers? I have also boosted the CR from the stock 8.5:1 to 9.8:1 - does CR have any effect on the optimal choice of header size?
Thank you.
Yes so be careful with OD vs ID . OD is how ALL tubing is measured so when someone refers to 1-3/4 it is usually .0625 wall and that equals 1.625 ID and down the line
I would also suggest looking at Dyno runs on a 3.2 vs 3.0 with SSIs which up until recently were all 1.5” OD and 1.375” ID again .0625 wall is common wall thickness. Yes cam and CR have an effect but you were at such a far extreme that you had no problem up top but low and mid range suffered (think track applications when running mostly higher RPMs) when street driving a car you want the best of both worlds but keep in mind you spend 75% of the time in the lower rpm ranges. You will experience better performance overall stepping down to 1.625 OD (again how all tubing and headers are measured across the industry) but you may leave some TQ down low on the table by not going 1.5”. I made a decision on my car which is a hot 2.4 to use 1.625 (993 exchangers) and sleeved them to 1.5” to maintain as much low end TQ as possible. It works amazing on my setup. Primaries length and collector design play a factor to in exhaust and ideally a 31-32” primary should be used for a Porsche 6 if low end TQ (street driving) is to be optimized. Typed this on my phone hope it makes sense
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-08-2024, 04:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #247 (permalink)
Racer
winders's Avatar
If you have radical enough cams, you could use 1 5/8".
What cams are you using? What size are your ITBs?
Scott Winders
PCA GT3 #3
Old 08-08-2024, 05:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #248 (permalink)
TheBrokePilot's Avatar
If you still have your SSI heat ex changers maybe you could take them with you and test 1.625" headers vs the 1.5" SSI's.
74 911 backdate project
15 Macan Turbo
Old 08-08-2024, 05:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #249 (permalink)
mb911,
Yes, your message came through clearly, thank you.
The Bursch 1.625" headers shipped from LA today and I will have them Saturday and installed Sunday. I sent more $$ to Gary Bains and am waiting to see when I get on his dyno schedule. I will let the dyno data tell me what to do next.
If need be, I'll research and purchase a good pair of 1.500" headers and repeat the dyno tuning a third time. Then I can sit down, look at the data, and decide which set up I want to run on my 911.
That is the absolute best way to do it though expensive there is no better way. Anxious to hear the results
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-08-2024, 06:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #250 (permalink)
Racer
winders's Avatar
40mm ITBs do not match up with 1 3/4" headers....
Scott Winders
PCA GT3 #3
Old 08-08-2024, 08:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #251 (permalink)
Jeff Alton's Avatar
So much converstation about the dip in the dyno plot I questioned.-- great posts by all that offered their thoughts. When you see that dip, you need to ask yourself "what is the cause?"
I think you are getting some good feedback. However, it is not always "this size header goes with that displacement".
This thread is LONG, which is great! But, can you refresh us on CR, Cam choice, ITB size along with the timing curve and AFR plot? Many vairables.
Thanks for keeping up the contributions and answering the questions being posted.
Cheers
www.turn3autosport.com
Old 08-08-2024, 09:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #252 (permalink)
Racer
winders's Avatar
Well, if you had a high output 3.6 to 3.8L race engine with 1 3/4" headers, you would expect to find ITBs with an effective diameter of 50mm to 53mm.
My current race engine which I have not dyno'd yet, is 3.746L with 48mm AT Power "shaftless" ITBs which effectively flow the same as standard 52.8mm ITBs. The engine has 1 3/4" headers and should make over 440 HP at the crank. The 3.6L version of this engine made 431 HP with 45mm AT Power ITBs (49.5mm effective) which were too small for the engine.
I have increased displacement 4.1% and ITB size 13.8%. I would not be surprised to see 450 HP.
That is double the power you are making with the same header size.
Scott Winders
PCA GT3 #3
Old 08-08-2024, 09:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #253 (permalink)
Racer
winders's Avatar
While I was wishing William "Happy Birthday!" today, I asked him about what cams he liked for a your motor. He thinks you don't have the right cams and your headers are too big. He did say you could get away with the 1 5/8" O.D. headers if you used a better cam. He would use the K45 cam. He sells them...I am not sure who makes them.
Scott Winders
PCA GT3 #3
Old 08-08-2024, 11:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #254 (permalink)
scarceller's Avatar
How long are those primaries from the head to the collector? 30-32" ? If so those are known as long tube headers and have a sweet spot tune point in the 5000-6000 RPM range and that's good for the 3.0 but 1 3/4" are a bit to large. Would have been better if 1 5/8" header.
But I'm most interested in the runner lengths.
Today I received and installed my new exhaust manifolds - Bursch 1 3/4 inch stainless steel headers. If I get cold, I'll have to put on a jacket....
Next stop, rent an engine hoist and get the engine off the engine stand, unite it with the transaxle and install the power unit into the car.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-09-2024, 01:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #255 (permalink)
dannichols1474's Avatar
Hi Sal,
I'll measure those runner lengths tomorrow and post them on the new thread I started to focus on this header size discussion.
http://forums.pelicanparts.com/porsche-911-technical-forum/1165423-exhaust-header-size-my-rebuilt-2-7l-motor.html#post12300226.
Dan
1975 911 Carrera
"CIS to ITB EFI conversion" thread
Updated (2) Table of Contents pg17 post 339
Old 08-09-2024, 08:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #256 (permalink)
Dan so back on topic. I also embarked on EFI this spring and went with the poorman solution and used my carbs as TBs and MS2 with a base map. It has been a good learning curve but I very happy with the results. Easy starting, great power, easy adjustability. So far the biggest hiccup was mismatched banks from throttle linkages and I have corrected that now. My question for you is do you think the dyno was worth the time and money or did autotune and big hills/foot on the brake seem effective enough? I have found the latter to work really well for me.
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-10-2024, 07:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #257 (permalink)
Ben, my experience so far has been that I can use recommendations for the AFR targets in the AFR table and then use the driving techniques you describe (plus ET's at the track) to get the VE table dialed in with auto tune, but I don't know what the ignition timing should be especially when I build an engine with non-standard parts.
So what I have read is ignition timing is where we can unlock hidden torque / power and to do that I have to run timing sweeps for various combinations of engine speed and load to determine the timing point that yields MBT (maximum brake torque) for each of those combinations and then I can build an optimized timing table for the ECU to use. That's where the dyno and a skilled calibration tech come in.
Long answer, short: I think dyno testing is good value for the money especially since I am not an experienced tuner of EFI plus I like having hard data (even if the data is relative and not absolute).
Dan
1975 911 Carrera
Old 08-10-2024, 08:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #258 (permalink)
Hi Ben,
In the last post I said I thought a dyno session is good value for the money, then I reread your post and I want to add that if you are using the ECU to control the fuel injection only, then tuning the EFI with the big hills/foot on the brake technique is adequate if you are happy with your results.
I bought Al Kosmal / X-Faktory's Option#2 conversion package that added ECU ignition control to the ECU fuel injection control, so dyno tuning made sense for me to optimize the timing settings.
Here is a photo of the ignition table before dyno tuning using timing values from the characterization of the distributor mechanical advance curve before I started the CIS to ITB EFI conversion project:
Here is a photo of the ignition table after dyno tuning using timing values derived from timing sweeps to determine MBT (max brake torque) at various combinations of rpm and load:
Dan
1975 911 Carrera
Old 08-10-2024, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #259 (permalink)
Interesting and thanks for sharing. I am using 123 ignition so yes correct no ignition added. It has worked really well. I was lucky enough to @jpnovak as my remote advisor for tuning. It really has gone well. I actually am surprised more people don’t use MS and opt for big dollar setups. It doesn’t make a lot of sense to me as MS seems pretty easy to work with.
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-10-2024, 09:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #260 (permalink)
