Fuel Expansion tank
I have a 1979 911SC, that I am adding an oil cooler on the drivers side. I want to know if I can delete the black expansion tank that is in the drivers side fender and add the clear expansion tank that came on later model cars that is located in the frunk?
Thanks.
Old 09-16-2025, 11:29 AM
the later cars still have the black expansion tank located above the windshield washer tant in the drivers side front fender.
Old 09-16-2025, 01:15 PM
Big, you want that black expansion tank. I think thats the charcoal filter. Without it the car smells like fuel al the time, and not in a good way. Ask me how I know.
Now you could relocate the charcoal canister into the frunk somewhere, but altho also requires reworking the vacuum lines that feed themes to the intake manifold a bit. My car didn't have a charcoal canister, so I had to make a system from scratch.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 09-16-2025, 02:09 PM
I believe the black expansion tank is just an empty plastic tank. I think the charcoal canister is in the engine compartment. Guess I have to keep doing some digging, I can’t be the first person to add a driver’s side fender cooler and need to relocate the black expansion tank.
Old 09-16-2025, 02:48 PM
You are correct the expansion tank in the front fender is an empty plastic expansion tank.
And yes, the charcoal canister is located at the rear of the car.
Old 09-16-2025, 03:03 PM
That little in-line auxiliary expansion tank on later models still connects to the larger exp tank. The fittings for hoses differ. Not sure about the size of the other but they’re big for a reason and have to be sturdy enough not to collapse from the vacuum or swell from gas tank fumes.
Curious - I’d rather relo the horns (if that’s the hold up) and put the cooler on the original passenger side set up.
BTW - Are you deleting the giant 2gal washer fluid tank in fender well and maybe putting in a generic 1 qt washer tank in the trunk too?
Old 09-16-2025, 08:06 PM
Thanks for everyone’s input. I am swapping a 3.6 VRAM motor from a 993 into my SC. I already have one oil cooler on the passenger side, and don’t want to do a chin spoiler, so want to put a cooler in the driver’s side fender.
I got rid of that big washer fluid tank years ago. This isn’t a daily driver, I don’t need a washer tank. Clean the bug off the windshield when I get gas. lol!
Old 09-16-2025, 08:36 PM
PCA Member since 1988
I removed the expansion tank (catch tank?) in the driver's side front fender. I put a "duck bill" cover on the pipe that went to the old tank. This allows pressure from the gas tank to vent. I do not get gas smell in the garage. On a few occasions, I will smell some gas in that area, but hardly objectionable. I have kept the expansion tank tucked under the cowl ahead of the instruments.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-16-2025, 11:47 PM
Do you happen to have a picture of the “duck bill” setup you are using? Thanks.
Old 09-17-2025, 09:07 AM
Just getting back to this. I will have to get a picture but here's a description: Imagine a short rubber tube pinched shut at one end. The pinch has a slit in it to allow pressure to push through the pinched tube. Auto stores sell them.
Use your favorite search to find "images of duckbill drain valves"
Old 09-18-2025, 12:27 AM
