Check with the Stable in San Luis Obispo (805-545-9323). They may have a car you can test your DME ECM in, or provide a loaner DME ECM.
Dave
Old 12-04-2025, 08:51 PM
Tori's Avatar
Originally Posted by wazzz View Post
To make it clear, the DME is actually the ECU. When you say you swapped the DME, I guess you mean the DME relay. If you have no spark, you don't need to try and swap the DME relay, since it has no relation with the ignition.
You need to check the basics. First make sure the ECU is powered on when the ignition is switched on. You can check this by listening in the engine compartment. You should hear the idle control valve (ICV) humming. If not that means the ECU has no power or is completely dead.
Next, if the ECU is indeed alive, you need to check if you have fuel.
If you have no spark, maybe you have no fuel either. In this case it would point to a failing sensor (maybe). The ECU won't allow any spark or fuel if it doesn't get proper signals from both flywheel sensors at startup. No spark no fuel is typical of a failing sensor or a failure of the IC inside the ECU that is used to format these sensor signals for the processor.
Okay.... here's where we are currently in this process.
-I have verified ICV is getting power. I can hear and feel it humming.
-I've verified i have power at DME relay on both pins, 86 and 30 (86 when ign. on)
-I've swapped coils with another Bosch coil (not 100% positive it's a good coil, but it's what i had. I do have 12v at coil.
-Checked ohm readings of speed and ref. signal sensors. 971k and 973k respectively.
-Pulled dist. cap to inspect, rotor looks fine, cap has normal buildup and does show wear on a few of the terminals - looks like rotor contacted a terminal at some point, but nothing looks excessive or beyond it being able to function. (at least to some degree). - I'll order new cap and rotor for later this week.
I'll pull the DME apart next and look for failed solder joints next.
Open to any other suggestions.
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 12-06-2025, 03:02 PM
-I've verified i have power at DME relay on both pins, 86 and 30 (30 when ign. on)
Read here again step B, i.e. voltage measurements;
http://forums.pelicanparts.com/porsche-911-technical-forum/621262-911-3-2-no-start-troubleshooting.html
Dave
Old 12-06-2025, 05:35 PM
Schulisco's Avatar
Sorry to say, but your tests are not appropriate. You cannot rely on simple voltage measurements of the DME relay. It's contacts corrode, and they fail more likely when heat (after driving some time) or vibrations rather than being cold with a sitting engine...
Tinker a three wire cable by yourself as I linked earlier, as this creates a solid and permanent connection between the contacts instead of errorprone switched contacts.
Your Ohm readings on both speed and reference sensors are not correct, the numbers you want to read is approx. 0.6 - 1.6 kOhms each. Not 970kOhms!! If the sensors really got these numbers, ther're crapped and have to be replaced! Place the test probes at the plug of each sensor directly! Otherwise you probably measure everything else but the sensors.
Visual inspection on ignition parts is senseless without electrical check. You want to read 4-6kOhms on each wire from plug to rotor cap. The rotor itself for the 3.2 Carrera has 1kOhms resistance. Wiggle the cables too while measuring to rule out broken cables.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-09-2025, 04:52 AM
I'm pretty sure he meant ohms and not k-ohms. Actually, 971 and 973 ohms are very good values for these sensors and they are very close to each other. At 970 kohms no way the engine would ever run.
As for the three-wire trick, totally agree. That's an easy way to eliminate bad contacts that are only intermittent.
Gilles
RoW 88 Carrera coupé
Old 12-09-2025, 05:45 AM
Tori's Avatar
Yes, thank you for clarifying that for me. I'm not super versed in electrical... i'm okay at DC current and simple tests, but not clearly versed in terminology.
Old 12-14-2025, 12:09 PM
Tori's Avatar
Thomas
I have 3 different DME relay's, one original, one replacement, and one solid state version. Can't see 3 of these failing at the same time. Pretty poor odds of that one.
I also doubt highly that all my plug wires have failed at once.
Thanks for the help though.
Old 12-14-2025, 12:13 PM
Tori's Avatar
Visited them last week. No help.
Old 12-14-2025, 01:32 PM
Tori's Avatar
I've run out of things to check...
Today i verified the wires from Speed and Ref. sensor connectors to the DME - all good.
Also made the 3 wire jumper for the DME relay connector, no change to my issue.
At this point, i have to suspect the one thing i cannot test, the DME. Is there anyone that tests them ?
Old 12-21-2025, 06:57 PM
Still here
pmax's Avatar
So far i've swapped 3 different DME's, and swapped the computer chip. Wiggled all connectors and inspected those of the DME and Computer.
To clear the confusion, you mean DME relays, not DME's.
Why don't you send the DME to a pro for testing ?
Old 12-21-2025, 07:31 PM
Read post #4. There's a link for a SoCal company who's been testing/repairing DME ECMs for 30+ years for Porsche dealers, independent shops, & 911 owners.
Dave
Old 12-21-2025, 09:48 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I can provide a loaner DME and/or test and repair yours as required. Reach out via PM if interested.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-21-2025, 10:27 PM
scarceller's Avatar
You already confirmed the ICV hums and vibrates with key in RUN.
Your next step is:
- Remove the center ignition cable from the distributor, the cable that connects the coil to the distributor.
- Put a test spark plug on the end of that cable and ground the plug
- Have someone crank the engine.
- Do you have spark?
Please do this test next.
You have not yet done all the possible in car tests, you have missed a few items that could be causing your no start.
Lets go slow with test by test.
Start with above test to verify spark or no spark at the coil.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 12-22-2025, 12:24 PM
Still here
pmax's Avatar
Appreciate your active participation in this forum, this thread being no exception.
Old 12-22-2025, 01:40 PM
Tori's Avatar
Did you read my last sentence looking for recommendations on who/where to send it ? Thanks for your help.
Old 12-22-2025, 09:57 PM
Tori's Avatar
Yep, planned to call them but also open to other suggestions. Thanks.
Old 12-22-2025, 09:59 PM
Tori's Avatar
Your next step is:
I appreciate the help, but there is no spark coming thru the new rotor and cap and thru any of the wires. I already know there is nothing coming out of the coil.
Old 12-22-2025, 11:46 PM
Tori's Avatar
Gotta give a big shout out to Ingo, we connected today and he brought me a known good DME to try in my car !
Clipped it in, and VROOOOOOM !!! The car came to life like normal !!
He's letting me borrow this one while he repairs mine. Great guy, and this saved me a few weeks of shipping mine off and waiting for someone to test it and ship it back to me.
Thank you to all that offered help and advise to get me to this point.
Old 12-22-2025, 11:52 PM
That's good to hear, well done Ingo.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 12-23-2025, 01:58 AM
