83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
and incorrect
http://forums.pelicanparts.com/porsche-911-technical-forum/750369-911t-00026-a.html#post7448372 Notice also the repetitive listing of 6190001-6192455 even for the 911E? And the correct numbers for 901/09 are 6290001-6292270 not 2455; sheesh, so many errors in one page.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 Last edited by djpateman; 05-18-2013 at 02:01 PM.. |
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Hello,don't know if this is the right place to ask this [I'm new at it] I.D.for chassis no.9113101905. eng.no.911/51*6124238*.paint code.936-9-3. Thank you,Michael.
Hello,Don't know if this the right place for this...but.ID for ch.no.9113101905.eng.no.911/51*61242??* paint code.936-9-3 thank's Michael [I'm new to this]
That's a '73.5 2.4 CIS 911T model - 911/51 is the correct engine type number for this model.
Paint code is Metallic Silver
Andy M&W 904 ... now gone GT-style 356C ... also gone |
6124238 is the correct engine type, but the wrong year. The body is a 1973, and the engine is 1972. 936 is silver paint.
Sorry - my mistake. It's a '72 engine as djpateman pointed out.
The engine isn't the correct type for the car either - 911/51 is an mfi 2.4T engine whereas the VIN is for the later CIS model 2.4T.
Thank you for that fellas. The car is silver,has on light colored sticker on l/h door pillar [rear] 2/73 and the corresponding chassis no. CIS fuel inj. 84000 miles.I bought it on 15 June 1994.g/box no. 915/02 7336383. Thanks again.Michael.
OK, I'm being lazy or impatient because I have the resources at home but I want to know now!! :-)
63D2223 930/10 Should be a 3.0 from a 1981 SC...... Can anyone cfm?
Brgds, Peter Baldauf 1967 912 1988 911 vert 944 TS 1969 911 E 1956 356 Conti 1983 911 SC |
That serial seems appropriate for the VIN so could well be the original.
Capitalist and Patriot
Don't have my book with me either. |
OK, that confirms what the PO claimed.... Euro spec from 83.... I just had my doubts. Now, next question(s) this engine has the air injection pump and catalytic convertor. Did Euro engines come equipped like this or are these possibly add-ons to make it compliant with California emissions? This car did come from Cali....
An euro spec 930/10 shouldn't have any smog pump (only for 78/79 SCs) or a cat w/02 sensor. However most got some form of em missions equipment when brought into the USA and federalized.
Stop all that crap off and put SSIs on it! These are great little engines. Luv mine. Being in SoCal it has to and does pass smog with cat & 02 sensor. |
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Thank you for that. I,m very disappointed about motor.It has cis [with metal inlet tubes] and I bought it in California U.S.A.in 1994. Regards,Michael.
Hi all. Hoping the engine number gurus can help out.
My old friend and mentor passed on a couple of years ago, (he was the PO of my 1975 911S) and he had some used motors squirreled away. Helping his family unload some of the parts, and I'm working to ID the motors at the moment, then determine some values. Two motors: 6105367 911/07 6533127 911/57 Any help would be supremely appreciated.
Kerry Plackmeyer 1975 911s |
Well according to the Red Book which is wrong from time to time, the Serial's Numbers does not match the engine type in both cases. But does lean toward the 911T model
![]() How sure are you of the serial #'s 6105367 ==> 911T ,911/08 US Sporto 911/07 ==> 911T, 6103501 - 60104547 6533127 ==> 911T, 911/59 911/57 ==> 911T, 6520001 - 6523284
