Autocross/Hillclimbs
930.101.103.4R
its 78/79 SC, which i believe is correct. the engine number is just random. why someone would stamp it with a random non matching number, instead of leaving it blank, i dont know. the only other suspect thing is that the 930/06 kind of looks like theres a 9 that was ground off under the "/" . Almost like the 930/06 was restamped too. ![]() ![]()
2x 1984 944 N/A; 1988 951S Silver Rose; 81 VW Rabbit Diesel; MK4 VW R32
President - Bridge City Autosports http://www.bcautosports.club |
It looks like it might have been a blank case with random numbers stamped. The case is certainly far later than 1968.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
They should start with 628 .
They must have lost their "6" stamp that day
64J03364 would be?
83 911 Production Cab #10
Engine Type 930/25
Fitted to 87 Coupe, Targa and Cabrio (US/CDN/Japan) and Club Sport (US).
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I was hoping some of the masters here could help me out. I have a 1980 911sc and we had a motor swap done in 1997....well we lost all the paperwork in our move and I don't know what we have in her now. She is not running, We live in California and was informed I that if the motor in her now is not an original Cal/CARB approved motor I should not bother with a rebuild. The number I pulled is:
64J02422...the J may be a 1 but it looks closer to a J. Thank you all in advance for the help. The car was my dads and passed to me when he got a 90 C2. We are going to attempt to get her running if possible before his 73 birthday in October. |
HELP... Need More info ... I had a 83 Turbo eng put into my 78 911 Turbo on the eng case is 930.101.104.5R and at the top is 930/66 .... And on the 4sp tranny is 85/15 .. I'm trying to find extra info on these two pieces from other sources that other members have ... Please PM me .. Thanks
The 641xxxxx series was type 930/16, 3l that was fitted to US/Cdn Model Year 81.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 08-08-2015 at 03:48 AM.. |
Thanks for the info. I'm pretty sure its not a 3 Liter as I loved that engine all the way to 429,714 miles-this engine has the FI system/config of the 3.2 Carreras unless its a Frankenmotor of some type.I do remember having to get the transaxle cut to fit sensors so that leads me more to the 3.2 camp. I guess I need to call Parts Heaven and see what Al can come up with. Thanks again!
What photos are you needing? Are you looking for the airbox? Its on the passenger side with the airfilter located inside. Its a square filter not the rectangle like I had with the 3.0. I do remember the flapper valve my dad had Bob Grimsby at RMG in sunnyvale add to keep the air box from blowing up.Tell me what you want shots of. I should be able to get it this weekend.
A pic of the Engine Type (close to where the Serial # is). Engine Bay from the top, close up of the distributor, manifold and air box.
The more the better.
Pics requested...Hope they help
Please let me know
Engine Code larger pic
![]() The code a bit larger |
Mystery solve...
Since it definitely a 3.2 by looking at the photos, i decided to check Wayne's book. Serial # 64J02422 is a 1988 3.2 liters Type 930/25 217 hp @ 5900 Rpm 264 lb-ft @4800 Rpm Some one replace the normal filter to a cone one. No power gain but it does cleanup the engine bay.
engine numbers
I know what it is....2.2 S and I am looking for it 6301329.
Last seen on a thread here many years ago (maybe) in an SC. Help would be appreciated. Could be anywhere, or in anything. May be disguised and wearing carbs instead of MFI. ![]() Speedo |
Numbers, numbers
Hi all - any help much appreciated on this one... I'm hoping to expand the garage beyond the 356 and am looking at a 1970 911T. The vendor has told me it is a US delivered car and imported back to Europe with matching numbers (although not in the original colour). He has provided the following information:
Engine: 6106153 Chassis: 9110100369 Transmission: 911 01 7103702 I took a look online and the chassis number stacks up. However, from my reading of the chart at the following link the engine seems to be for a Sportmatic from 1970. Unfortunately there is no Certificate of Authenticity... On discussion this way and assuming the numbers have been correctly provided, thoughts are this might be a US delivered 1970 911T Sporto with original engine but converted gearbox to a manual... I'm afraid I don't have the Red Book - any help really appreciated... Porsche 911 C- und D-Modell 1970/71 Many thanks
_________________ Kenyon 2 Parts Coffee 1 Part Gasoline 1960 356B Silver |
How about this one?
67 911 vintage racer twin plug hotrod, 85 Carrera, 69 Blood orange 911S, F V F 906 longtail, 308 GTB, Hemi Coronet and some other junk. |
69E engine not 70S engine
