Clear powder coat intake runners?
Anybody have experience beadblasting and clear powdercoat there intake runners? How does it turn out?
Eric
1975 911 Carrera BLK/BLK
Old 09-19-2003, 05:56 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Are you considering the coating?
If so...be advised the inside of thee runners may be rough for a reason..to help keep the fuel particles suspended.
If you polish the insides...or powder coat them...you might end up with some problems with too rich or too lean in some cylinders.
Bob
Bob Hutson
Old 09-19-2003, 07:09 PM
Zeke's Avatar
He can coat just the outside. I clear powdercoated my fan shroud on my 914 race car. Looks like it was dipped in plastic. Easy to clean though.
Old 09-19-2003, 07:21 PM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Hey Eric, you might want to consider Chrome Powder here what it looks like on a fan shroud.
And on Valve covers,
Jorge (Targa Dude)
Old 09-19-2003, 09:17 PM
Cool
I just received the Por-15.. 2 part clear Glistein PC for my intakes, linkage and carbs.. bullet proof.. cost me $27 for a pint......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-19-2003, 09:57 PM
Thanks guys, I am deciding between the three 1.) Clear Powder coat 2.) Clear coat spray paint 3.) Paints silver high temp paint. Of course I will bead blast first. Just thinking which is the best?
Targa Dude, Your powder coat looks excellent. I just did the same Powder Coat in high gloss chrome to my fan and fan shroud and it came out horrible. My fan had alot of imperfections on the blade casting and the high gloss showed everything. The fan housing didn't outgas properly do pimples are everywhere. Worst is it cost me $250. I had the strap and pulley chromed dipped.
I am having them strip the fan and housing and try a flat finish.
Eric
Old 09-21-2003, 06:19 PM
Randy Webb's Avatar
Glistein?? Tel us more...
Old 09-21-2003, 07:05 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Eric,
Here is a close up of the runners and the fan/housing with a bead blast and the clear VHT poly.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 09-21-2003, 07:28 PM
Charlie thanks. This is the way I want to go with mine. Did the VHT Poly come in a spray?
Old 09-21-2003, 07:34 PM
Charlie just found it at Jegs.com. Thanks!
Old 09-21-2003, 07:40 PM
Cool
well I do like powder coat. I think it's a great coating.. But I'm in a serious paint environment living in ocean air.. so I shoot urethanes for survival.. and the Por-15 led me to their clears a few years ago on my mag fan.. yeah, it's chipped.. but the finish still looks great as on bare mag..
So I have new intakes and want to clear them to keep the new look and Por has a newer 2 part clear for big bucks.. it's high gloss only and I may use some Dupont white polishing compound to break the gloss on the new WaterShields I shot today.. so this stuff remains somewhat flexable/but hard and chip proof.. and if I clunk the parts with a wrench I won't even pay attention.. So it's really how you need the paint to perform..
Arizona guys have less constraints............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-22-2003, 12:21 AM
slater's Avatar
targa dude, what kind of powdercoat is that? my local place has got something called almost chrome, is that what it is? it looks very nice
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 09-22-2003, 09:00 AM
limble's Avatar
The intake runners on my 2,2 with Zeniths are powdercoated inside and out. Should I strip them? Rough up the insides a bit?
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 09-22-2003, 09:30 AM
Targa Dude's Avatar
Hi Slater, My guy calls it , Chrome Powder sounds like your guy just calls by a differnent name. the most inportant thing about using Chrome or almost Chrome powder is, you have to invest some time in the preparation of the metal, sanding out imperfections and even a minor polishing using buffing wheel and if its Mag you definately have to bake it out prior to coating which really helps out final appearance.
Jorge (Targa Dude)
Old 09-22-2003, 09:44 AM
Irrationally exuberant
ChrisBennet's Avatar
Bob (Hawgryder): The intakes are "dry". The rough texture is only important after the injectors. On the 911 that would be the intake side of the head.
Ronin: I used the 2 part Glisten PC on my semi-polished fan and fan housing and it peeled. The porous casting probably needs more than than the normal hand degreasing I did in order to get the oil out of the metal I suspect.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-22-2003, 10:38 AM
Cool
that's interesting.
I shot the fan with their single part clear 40k mi ago and it hasen't peeled.. I blasted before the shoot.. thanks, Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-22-2003, 10:46 AM
Metal Guru
911nut's Avatar
Bob
Bob, the fuel is injected just ahead of the intake valves in the heads.......only air travels down the intake runners.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-22-2003, 12:06 PM
Cool
I'm with Bob on this one
A rough surface is for building a "boundary layer" along the metal to aid gas flow.. Polished metal has less friction at high rpm, but not below high rpm. The "boundary layer" of somewhat trapped gas reduces friction at below high rpm..
Air is a gas
Air is a liquid
I'm not an expert.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-22-2003, 02:57 PM
