just me
new chip
just put a new chip in my motronic system for my 3.2 carrera.
the motor is transformed. it is still bone stock with cat and standard heat exchangers and muffler. got the chip on ebay from a seller going by "turborob" it cost an eighth as much as a steve wong chip. is the difference that much in performance? |
Me like track days
SHow us the auction link
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
just me
Me like track days
Looks like the chip says RPM Performance. WHo?
Good luck.
Somewhere in the Midwest
Wonder if they copied Steve's chip.
Paul, are you running 93 octane? Any pinging under load? |
Location: member Central PA Region PCA , Home of the Hershey Swap
Hope it works well for you. I bought a Steve Wong after years of trouble with other chips. The thing is that Steve customizes the chip for your car, fuel etc..
Now I'm sure Loren will be along here sometime. regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue |
just me
just me
RETIRED
Paging Loren....please pick up the white courtesy phone....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I have had the headers and dual outlet B&B for about 7-8 years. The muffler clamps broke early on and they FED-Exed a new set that have been fine since. The guy that installed said he would never do another. He com[plained about the fit, but I wasn't there and I don't use him as amechanic anymore for other reasons. The muffler does resonate in a drone at 2600 RPM or so. B&B is not the only one to resonate though. At some point I wouuld like to put a sporier exhaust on the turbo, but I will not install anythng that I haven't heard, outside of and riding in the car. That would be my suggestion to you.
regards, Steve
just me
Sounds like a great deal for $40. Sure beats paying over $250 for a performance chip.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Loren Wrote:
regards, Steve
"Wait, wait ...let me get this straight, it's "great deal" and OK for him to install this chip because he only paid $40 for it. What ever happened to you poke your eye out, blow up your motor and all the other stuff. Might not a $40 chip do it better and faster. LOL
regards," If you can't resist spending your money on ????, what's better; $40 out of your pocket or over $250? My sympathy to those who did the latter!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 01-07-2005 at 10:06 PM.. |
timeless beauty
keep me updated on this chip, I have a stock 87, it has the #10 jumper conected on the dme (calf. car) I haven't disconected yet it seems that the thing to do is disconect for a 8hp increase? any change in idle when replacing chip? What info did you get for install mybe you could post. Thanks |
Me like track days
Seems that chip is an unknown quantity. If it is then proven to work......price war!!!!!! ;-)
just me
no change in idle with the new chip, the directions were simple and brief and so was the chip swap. all you have to do is remove the computer from under the seat, carefully pry off the metal cover and open up the mother board. if you have an early 87 than you might have a 24 pin chip, seems porsche went to a new mother board during 87. my motor came from a later 87 model because it has the 28 pin chip. I have not had the car dynoed so i don't have a clue about horsepower differences with this chip over the stock one, but it really does run much better than before and is loads more lively. nearly spun the car last night shifting from first to second up hill in a spot that I have driven many times, so the power is much more available right now with this chip. it is 33 degrees F today and the car starts just fine and has no issues yet. it will be in the fifties during the week so I will get a chance to see how it performs in a little bit warmer weather. still no sign of knocking or pinging. |
Me like track days
Installing an unknown chip is analogous to using an unknown operating system for your PC. (No Microsoft cracks needed here......;-)
just me
yeah, I know what you mean. I still have the stock chip and keep it in the car just in case this one starts to go hay wire.
Should I get a diagnostic check done on the motor to see what it is that the chip is doing? There is a really good porsche specialist shop that I go to for alignment work. They do all kinds of work from restoration to preparing carrera cup cars. right now they are preparing race cars for daytona and sebring, so I imagine they have an idea about good and bad modifications.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
RETIRED
You can get a dual chip custom burned that allows you to flip between stock and performance chip.....the part is like 25 bucks....
