MAGA
Mark, when you say "it's cold here", I living in Ohio, do not feel much pity! Looks like a logical progression on the choice of sealants!
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
I hate freight charges
Good luck Mark, keep us updated!
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
Great post / write up Mark. Recently my shop did this on my 83 SC, he mentioned the finding 'red stuff' / never seen it before.. old school wrench. Trying to find out what he used to seal it all back. Red stuff = someone did this before on mine. It's running great now, and no leaks. Will let you know what he used to seal it back, probably..more red stuff.
Rika |
Mark, As I might have mentioned above. My friend is barrowing my ROW fuel distributer as he has someone rebuilding his. I was told the rebuild kit cost is arround $82 dollars. I am begging him to get info from the guy who's rebuilding it. First, where did he obtain the part numbers for the rebuild kits. Second, where did he source the kit.
I bet you wish you had the kit in your hands last week for $82. I'm going to keep pushing for this info!
Bill Miller 81 Targa Guards Red 3.6, M&K 1 out, S4 brakes 83 ROW CAB Rubinrot Metallic (RIP) |
Somatic Negative Optimist
Bill: By all means. Try to get the info, please.
Mark: Best of luck. My guess is that it will seal. The Loctite 574 "Flachendichtung" can be translated as "Flat-surface sealer" and indicates to me that it is designed for the very purpose of getting two finely machined/polished surfaces sealed. Is there a way that you could upload the instructions in German? I could translate for future use things like: What thinner to use? Drying-time? Resistance to gasoline?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
There is a short write-up from Chuck Stoddard on rebuilding fuel distributor heads on page 117 of volume V of "Up-Fixin der Porsche."
This article, written in 1977, recommended Loctite 242 for re-sealing the unit, with the following caveat: "If you use too much and it flows in the wrong place, you'll seal off a place that shouldn't be sealed, or you will have an interior lead from one chamber to another. If you are familiar with these units, and you use a little skill, you can rebuild one in two or three hours comfortably, and that's $100 (in 1977 dollars) an hour to your advantage." Last edited by 1982911SCTarga; 03-25-2006 at 09:35 AM.. |
Reseal Update
I managed to get the system put together and pressurized by jumping the fuel relay. As the entire system was void of fuel it took about 15 seconds to come up to head pressure. It made some unusual sounds as air purged from the lines and FD.
I'm proud to announce that after several test runs there are no leaks! I let the engine run till it came up to operating temp and everything appears fine The mixture seems very rich now. I suspect that with all the crap removed from the system the actual volume of fuel is improved. I didn't have time today to fine tune and make some power runs but tomorrow is another day. Mark
1981 911SC Sunroof Coupe 2005 Volvo XC-90 2.5T Vans RV-8 Experimental Aircraft |
Good to hear it all worked out
It's always nice to see someone de-mystify something that can cause so much problems. And it's even better when it can save us some cash. Surely this is worthy of a spot in the next "101 projects for your Porsche" book
Very nice and professional work. I'll be interested to hear of your impressions on how the motor runs compared to before.
I believe the Loctite 574 is the sealant used to seal the joint between the tops of the cylinder heads and the cam carriers, is it not? ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Very good so far; great effort with the documentation. If we can find a source for a rebuild-kit, the mystery of the FD might be easier to tackle.
Mark.
So what address do I send my FD too?! Your the man! Just tell me how much and I'll send it over.....Great job and by far one of greatest posts I have seen in years. Bob 1973.5T/CIS |
FWIW, you would have no problem seperating the halves if you had used the Loctite. I used it and then pulled it apart without a huge hassle.
Dave |
Thanks for diving into CIS uncharted territories. Very nice documentation too.
John Adams 1980 ROW 911SC |
Designer King
Excellent thread!
You are probably right about your mixture setting. Keep us alerted.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Thought you guys might like this...............
It is a Fuel Dist Valve Kit K-Jet PshVlv http://oem.overnightautoparts.com/parts/overnightautoparts/wizard.jsp?year=1983&make=PO&model=911--005&category=C&part=Fuel%20Dist%20Valve%20Kit&dp=false |
I managed to find this on a Delorean Parts web site. It could be retrofited (note banjo style fittings) with a little effort. Mark
They also have HOOD SCOOPS!
http://www.overnightautoparts.com/performance/basket.php?makeid=23&modelid=487&year=1983&partid=180&brandid=706&skipped_brand=true Rich
1976 911/S/SC/BASTARD Mid9 Member #12 |
