911's take some thought to develop them on the cheap. Problems are varied, and relatively few bother to pursue it. Sketch shows that things are possible.
Obviously, not as simple as bolting up an edelbrock as I did in 928 trim. Other than cleaning, not one problem with it. Very good metering device. ....$125 years back. .........
- Fuel distribution wasn't ideal (could be improved with add'l design and R&D. - Throttle response would lag as a result of the distance from the main and accelerator pump discharge ports to the intake valve. - Cold start and cold running issues to resolve If individual fuel injectors are located closer to the intake valves, then air/fuel mixing in the intake manifold is no longer an issue. Sherwood |
Big mystery is why no one has been able to offer a low end carb setup each side of the motor, with plenum, linkage, and cold start ability.. Two of these (or 3) each side - would handle lag and mixture problems you cite. Inexpensive single barrel carbs might surprise some people.
Single throat Mikunis, Strombergs, Dellorto, etc. carbs have been previously installed by various people. I assume they have worked after dealing with adapters, linkage and mixture settings. In addition, they're probably more adaptable/tunable than the average vintage domestic Rochester or Carter carbs (throat/throttle bores, jetting, etc.)
The average enthusiast is most likely satisfied with the factory carbs which work fine other than the cost of entry (from EFI/MFI) and needed refurbishment. In addition, the factory Weber and Solex carbs are quite tunable (less so for Solexes) with a large library of tech info as it applies to our cars. Sherwood |
These two barrel IDA's are offered in 50, 52, 56, 58 and 60mm...
http://www.geneberg.com/images/IMG_0747%20(Small).JPG |
The decklid fans on water cooled 911s are most likely for the A/C condenser right above it. Sherwood Last edited by nostatic; 11-10-2014 at 11:13 AM.. |
